Any body tried to repair a folding rule?
I have several Lufkin folding rules that are broken. Any possibility I could take two and make one good one out them? How would I deal with those rivets?
(Packrat gene is twitching here.)
Re: Any body tried to repair a folding rule?
Lee Schierer in McKean, PA
As I recall, my grandfather used to repair his. I think the wood is just crimped in place by the hinge. You have to carefully remove hinge from around a good section you want to use and get the wood out of the broken section hinge. Then slide/pop it into the hinge where you want to connect the two pieces. Some glue might help retain the pieces in their new locations.
Lee
Not a lot to lose
Gary smyth
Give it a try by whatever means you find works, but I would somehow mark that rule as the measurements for the new version will probably not match any other measuring device. If a 1/4" +or - doesn't matter, it might be worth the time. However. with Harbor Freight giving away free (metal) tapes as incentives two or three times a year I'd do it only as an exercise in trying something new.
At house sales perfectly good old ones go for $1.00. I see a lot of them as I look at basement work benches. I use mine not for measuring, but to find and transfer angles (as in bird's mouths). A shortened folding rule can help with inside measurement, I mark the measurement with pencil and mostly ignore the scale -- and you don't worry about a moving metal tab as are on metal tapes. In such a case a broken folding rule serves as well as a whole one.
BrianMonumentCO
Having a little Scottish blood, I will attempt to repair anything.
I once upon a time repaired a Sears Craftsman 3/8 inch corded drill that was making a horrible noise.
Probably took a couple hours. Would have been cheaper to replace.
But I still have it and it still works.
