Friend of mine has a ceramic tile tooth brush holder installed in the wall in his bathroom. Its broken. He has both pieces, the one that came off and the part still in the wall. Its a rental house. How would you glue it? Or would you glue it? How would you fix it?
I have epoxy and Cyno acrylate. How would you hold it in place long enough for the epoxy toe set?
I'll agree with Mark, but would like to point out that all CA is not the same.
I don't think I would use that with the thin / fast, it may kick before you find the exact alignment. I'd use the medium. You can put it on both parts, and push them together to find the alignment, then just tilt out for a quick spray of accelerator, then back together with much less risk.
Its basically what they use to fill voids in stone tile, works great. Run of the mill 5 minute should be fine for what you describe. Definitely not CA glue, as Bill said, it tends to fail.
