split oak
split oak
split oak
wayne
I am trying to repair an old rocker that is made of white oak. It has bent arm rests. I either need 4 pieces of white oak split and not kiln dried 3/4" thick by 2 1/2" wide and 36" long to try and make them myself or need a name of a binder the wood needs to be green wood. Where I live in West Texas there aren't many White oak trees lots of red oak but people look down on people cutting trees in there front yard.
Re: split oak
Re: split oak
Tom Dunlap
I sent you an email.
An arborist friend works in central/west Texas and should be able to find you some green oak for the project.
Be sure to tell him that I sent you,
Tom
Re: split oak
Re: split oak
Keith Newton
How much bend is there in these parts, and have you ever dealt with bending before? Sometime parts can be band sawn out of thicker stock if only slightly bent.
But then steaming works best when the MC is around 18%, and I may have some WO at about that.
Re: split oak
Re: split oak
Ralph Lipeles
When bending I have had good luck with a simple setup. A piece of 4" pipe (I actually used cardboard from the roll of carpeting) with a hole in the middle to fit the nozzle on my teapot. Drill a couple of cross holes for 1/4" dowels to support the piece to be steamed and then bent. Support the 4" tube at both ends and loosely stuff a rag into each end to contain the steam/condensate. Leave some open space at the ends to insure that the steam will flow and completely fill the pipe. Steam for about 1/2 hour and try bending. Make some extra pieces as they sometimes break.
Re: split oak
Re: split oak
wayne
Keith is it kiln dried or green? I understand that it is better with green lumber that is split instead of sawn.
Re: split oak
Re: split oak
wayne
made contact he will see if he has something
Thanks
