Resin powder= Urea Resin
Grant in Iowa
I think Bill is talking about Urea Resin glue, or Urea Resin.
Great stuff, water proof near as I can tell. Dap Weldwood is the major seller, sold under "Dap Weldwood plastic resin".
This stuff comes as a powdered product, looks like cinnamon & sugar, but use it in a ventilated area due to the (I think) Formaldehyde it gives off when curing. Food safe once cured, I was told by tech support when I called them.
I made several water skis with with a bentwood lamination process clamped via vacuum press and had excellent results. Reliability of the joints have been better than anything else I have found. These skis are used in a show ski club, so they see plenty of abuse and water 8 months a year. As far as I know, there's nothing better for a wet environment than perhaps the purple Resorcinol.
The product also resists glue creep, which can be a problem on bentwood projects. And, it is much more resistant to heat than the common variety of epoxies. Our ski team had issues with epoxy glues gelling and failing when stored in a hot environment like an enclosed trailer.
The only drawback I can see is the shelf time is about two years. It won't mix properly, nor bond well much beyond that time frame. So buy what you need and use it up. When storing it, keep it cool. I usually leave it on the floor in its plastic bucket.
Regards,
Grant in Iowa
