Need a drill bit. Don't know what it is.
Joe in a Cleveland suburb
Hi all.
I need a drill bit to drill into the horn of some animal from Africa. I know, sounds weird. It's a Boy Scout thing. These horns are made to make, well, horns that you blow through.
My brother showed me a working example that was given to him years ago. I don't know how it was done. He bought some horns on line and wanted to know if I could drill the hole(s).
There is one smaller hole that goes through into the cavity of the horn. There is a larger hole that is like a (about) 5/8" dimple. Or hemisphere. Not sure I am describing that correctly.
But, what kind of bit should I look for/ask for that will leave a dimple like that. Almost like a small pipe bowl. I don't even know what to call it. :\
Any suggestions?
What about the somewhat flat area where your lips go? Any clever ideas on how to create that? Spokeshave? I've never messed with material like this, not sure how it will react to various tools.
This is the sample one:
Re: Need a drill bit. Don't know what it is.
John in NM
The dimple looks like it was done with a router bit, something like a core box bit. You could do something similar with a round nose carving burr if building a jig to hold the horn for routing is too time consuming.
Keith Newton
I would drill the small through hole first, then use a cove bit in the router for the outer hole. You may need to use a cheap HSS if the bearing is too large to fit the smaller hole on a carbide cutter.
Dick Coers
Are you talking about the large area? I'd do that with a sanding drum in a Dremel. There are bits called counterbore bits. They have a smooth pilot that guides in a previously drilled hole, and cuts a larger flat bottom counterbore.
Bill Turpin in WNC mountains
I would drill the large hole first with a regular drill bit. Then drill with a small drill bit. Done in the opposite order the large bit will easily catch and drill all the way thru. Horn can be cut with hand tools. This should be easy to do.
Grant in Iowa
Joe,
It appears the flattened, yet concave area was done with a carving knife or rounded chisel due to the faceted look. You might consider using a drawshave if you have one, just work from each side towards the center so you work the material "downhill" to avoid tearout.
The flat bottomed hole could easily be duplicated using a forstner type bit. I have drilled deer antler with them, and they work fine on that material. I assume it will be similar in composition. Suggest a drill press and clamp down the horn securely. Assuming the horn is clamped properly, you can drill the center hole first. Then, while it is still clamped down, swap bits to the forstner bit and drill the flattened depression. Go easy as the bit enters the work until a shoulder is established.This is reverse order of work of what I would normally recommend, but firm clamping makes it possible. I suggest this order because you won't know how thick the horn is where you are drilling until you go through with the center hole. The overall depth will determine your cut depth with the forstner bit.
It may be critical to have the hole depth and flat area as close as possible to the original to get the sound to work right. The depth of the center hole may also be critical to getting the sound right. Thus my suggested order of work.
You might do your hole drilling first, and then shave the area around the hole down to match the original as close as possible.
Be advised that it will smell like burning hair, which is one of the worst smells in my opinion.
FWIW,
Grant in Iowa
Similar
A forstner bit should do the large round, but I would suggest to first drill a 1/8" pilot hole to use to determine the wall thickness which you'll need to control the depth on the forstner. Next cut the forstner, then, last, redrill the center hole to size with a good sharp twist drill. The pic seems to indicate the "flat" area was made with a file and/or a disk sander.
Jim DeLaney, Austintown, Ohio
A core box router bit chucked in a drill press will do it, or (cheaper) you could re-grind a spade bit.
Thanks for all the advice/ideas.
I'll make a jig to hold and clamp the horn to the drill press. I'll drill the smaller hole first so I can see how deep I can ho. Then I'll drill out the dimple part with a core box router bit in the drill press. I'll go slow.
Might need to create the flat area first before drilling.
Should be easy.
Thanks again.
Flat area *LINK*
John in NM
You can also use a machinist's center drill to start the hole, they don't walk like twist drills on a round or uneven surface.
center drill
