"Hardened" Shellac?
"Hardened" Shellac?
"Hardened" Shellac?
Been investigating an alleged additive to shellac that works as a cross-linker and increased hardness and resistance to alcohol.
Anybody here used the "stuff" and have information and sources?
Re: "Hardened" Shellac?
del schisler
i haven't heared anything like that, shellac is mixed with alchohol ? you know
Re: "Hardened" Shellac?  *LINK*
mdclor
Mark, I Googled it and found the below link. There isn't much info presented, but maybe you could contact the manufacturer to get your questions answered.
Shellac Hardener
reply, but why?
Shellac is already hard. We all know that because it rubs out easily. What it isn't is tough. The molecular weight is too low to be tough. Precisely cross linking it to the right extent with a cross linker of the right properties, if such an additive has been developed, could toughen it and render it insoluble. But, if that is the need why not just use a urethane, legendary for toughness?
Got That
from a guy on the AAW turning forum.
Several issues:
1. You have to mix a large amount (4 liters) because the "product" is (apparently) not homogeneous in the bottle and must be used in a single mix and then allowed to sit for 3 days before use.
2. You loose the great advantage of current shellac and lacquer finishes, that being 100% burn-in for repairs.
3. They seem to want industrial grade DNA and exclude use of "hardware store" alcohols.
Since I use shellac as an intermediate step in my finishes, the advertised benefit of a more resistant film is not as important to me. The long pot life (18 months) and increased toughness would be important, especially when using toning applications, to counteract cold checking under my waterborne top coats. For me, the issues outweigh the benefits so I'll pass on the stuff but file the information for future consideration.
Thanks for the google ;)
Why
Seems to be popular with Luthiers who are looking for a more durable 1-product application with the ease of application methods that are unique to shellac. Shellac has, for centuries, been the preferred finish for instruments.
While it's an "advance" in coatings technology, I suspect it will be by-passed by the acrylic lacquers.
New To Me As Well
Stumbled across it in a discussion of friction polish for turnings. Seems to be more of an Aussie thing used by Luthiers as an additive to alcohol-mix shellac.
