Chair glide question
I refinished my dining room floor, used Varathane with aluminum oxide in it. My chairs have nylon or hard plastic glides on the bottoms of the legs and they are scratching the floor. Whats better? Felt glides????
Yep.
Jason Roehl in Lafayette, IN
The other part that is important is to keep the floor clean. Dust is an abrasive that your shoes and chair legs will use to scuff the floor. A regular, quick once-over with a microfiber cloth of some sort should do the trick.
Jason
Re: Chair glide question
Ralph Lipeles
Barry,
I find that the felt glides that you buy quickly fall off so I make my own using 1/4" felt, a 1" diameter punch and epoxy. I do one chair at a time. With the chair upside down on a bench I mix up some 2 part epoxy and put a dab on the bottom of each leg. I use 2 pieces of masking tape, square to each other, to hold the disks s in place. Let sit 24 hours and then do the next chair. I did my chairs 4 years ago and all pads are still in place.
Hmmm? Wonder if leather would work?
I don't have any felt, but I do have some leather.
I bought a swiffer today to help keep the floor cleaner.
don stephan
My expectation is that nylon glides might mar the surface, but not actually scratch it. My expectation also has always been that felt and similar are more likely to have grit imbedded in them and thus more likely to scratch. Don't know that there is a perfect solution.
Solution: Lift the chair
