OT – Plywood Underlayment Movement Question.
DONinSTL
Does anyone know the dimensional stability of plywood underlayment?
I have a small bathroom floor area that is only 5 ft. x 5 ft. It is presently 3/8-inch plywood on top of 1/2-inch plywood sub-floor. It sits over a temperature controlled basement in the center of the house.
Before installing vinyl tile I will be installing a water resistant, plywood underlayment that is .2-inches thick. It will be stapled down with quarter-inch staples.
My question is, on a floor of this small size can I lay the underlayment tight against the ceramic wall tiles, without an expansion gap? Or, will there be enough movement in the underlayment that an expansion gap is absolutely necessary? I have reason to want to keep it as tight as possible.
Thanks for any help.
