Samantha's dresser- sanding and staining
Sanding and staining The secret to good staining is proper surface preparation. One must not mistake sanding to 1000 grit with proper surface preparation. Proper surface preparation is uniform sanding to remove all machining defects to a grit size appropriate for the wood, stain and finish. In my case I end at 180 for this project.
For this project I began with 120 grit for one part and 100 for another part, determined by how much machining defects I needed to remove. Hence, my sanding sequence was 100, 120 and 180.
PIC 1 defects visible
The first picture shows an inadequate amount of initial sanding. There is a glue stain top left and some faint planer ripple on the top center. Good light is a must.
Pic 2 torn grain not removed
In picture 2 we see a dull place indicating torn grain that has not been removed. Any place that is dull after the last sanding step is a place with torn grain. The torn grain is catching sanding dust and it will similarly catch pigment stain. These places will absorb stain more than the rest of the piece and make a dreaded blotch.
PIC3 end grain
End grain must be bright after the last sanding step. In this case it will stain no darker than the flat grain.
PIC 4 Finished side
This picture shows the finished case side. It must be a uniform dull at his stage, indicating no torn grain, planer burnish, or glue stain.
PIC 5
This picture shows the stained back of the top. The stain is 10 % Japan color Burnt Umber, 10% linseed oil and 80% General Finishes wood conditioner (which is what GF uses for pigment stain base). For this piece I stained a bit lighter than typical to enhance its more modern look. I compensated for less stain with a bit of oil to enhance the figure. Stain is applied with a rubber like shellac, squeezing out stain as the rubber is rubbed across the surface. With this technique over staining is avoided. Only about 50 mL of stain was used for the whole case and probably half this amount is stuck in the rubber. You can choose to like the stained color or not. It is what it is and will largely stay that way forever. My monitor shows it a bit redder than reality.
PIC 6 stained side
After staining the figure in the wood begins to come out. It will come out more when the finish goes on
PIC 7 finished piece
