Samanths Dresser 15- frame and panel back
Samantha’s chest of drawers- the back
For the last few case pieces I have used a paneled back and I have come to like it. In this case I had a 10”x 16’ cedar board from the house that Samantha first lived in. This house was built in the 60’s and the roof was decked in 1 x 10 cedar. Different for sure. A spare piece was left in the attic. I like to incorporate meaningful wood into a piece when it is practical.
1PIC mostiser
I make the backs with 1/2” thick frames and 3/8” panels. The ¼” x ¾” deep mortises are made with a drill press dedicated to mortising. In a recent Popular Woodworking Bob Lang spoke unfavorably of this means of making a mortise but I have used it successfully for many years. One thing I do different is that I turn the drill as slow as the drill press will go. I find that clamping the piece to be mortised improves centering accuracy.
2PIC tenon sawing
The tenons cheeks are made on a tenon attachment for my table saw. Step one is to scribe the shoulder line. Then one face of the tenon is sawed with the length just shy of the scribe line. A spacer is added behind the piece being tenoned and the second face sawed as shown in the staged picture (forgot to take this picture when actually doing these parts). This spacer is uniquely sized for the width of the saw blade and the size of the mortise. It must be precise to just a very few thousandths of an inch for the tenon to fit properly. But once it is made the tenons can be rapidly cut for the mortise bit used.
3PIC trimming shoulders
Finally the tenon shoulder is trimmed to the scribe line with a chisel.
4PIC tenon length
The length of the tenon is measured from the mortise length, marked and the waste sawed away.
This is a slow way of making M&T joints but it reliably results in good fits, especially at the shoulders. I have failed to get good joints when I use shortcuts.
As a matter of philosophy, this is the back of something that may never be seen. There is no practical reason to be fussing about perfect joinery here. However, at the rate I build stuff it is difficult to stay in practice, especially on dovetail and M&T joints. So, I use things like this back as practice pieces to keep my skills up or even improve them.
5,6PIC measuring lengths
I find that measuring with a ruler is not sufficiently precise to get a panel of precise size with tight joints. I take the measurement of the internal frame parts off the external frame once it is dry assembled. Same for the panels to added later.
7Gluing
Gluing up this puzzle can be stressful. It is less so if all the parts have been dry fit and laid out as they go into the panel and the clamps selected and adjusted to length. Note I have marked the back of panels so as to not get any reversed during the haste of assembly. I use liquid hide glue to allow a long assembly time. This glue also lubes slidy joinery.
8PIC finishing
I prefinish the raised parts of the panels before assembly so if the panel shrinks an unfinished line will not appear. For spraying stuff like this panel I use a crude spraying easel. It took about 20 seconds to finish this panel, which is why I invested in the equipment and experience to know how to spray finish. The finish is some dull varnish I had left over from another project. It was near 90 the day I sprayed and it was dust free in 30 min.
Re: Samanths Dresser 15- frame and panel back
Don Orr
I'm loving this project and the progress you have shown is very informative-thanks!
If you don't mind, what did you write on the inside of the back?
answer
The writing describes that the lumber came from the house Samantha lived in after she was born. If the lumber is something special its provenance will be described somewhere in the piece, in this case the back of the back.
Re: answer
Joe in a Cleveland suburb
"The writing describes that the lumber came from the house Samantha lived in after she was born."
Bill, thanks for the updates on this project.
What did you write with? Is it considered permanent? Does the finish affect it?
Thanks.
Writing lasting notes on furniture
About any art store has "Micron" brand drawing pens with archival ink. They don't seem to wick on wood. Write the notes then overcoat with some clear finish like shellac. They make them so small (0.005 mm that I can make notes on tiny turned Christmas ornaments.
Thanks Bill!
Don Orr
I thought it might be something like that.
Beautiful work as always and thanks again for taking us along on this journey.
