Fertilizer Spreader problem
Ed O'Neill
I realize this is not a woodworking question but I'm hoping someone will have some info that I can use. I have a Lesco spreader that I purchased a few years ago when I used Lesco fertilizer. I have since changed to Scotts fertilizer but cannot get a conversion table for the settings. I've contacted Scotts and Lesco and get the runaround regarding a conversion table. Both companies suggest laying out a 10x10 area and doing tests on both my scotts and lesco spreaders. It seems to me that there has got to be an easier way. If anyone has solved this problem or know of a conversion table it would be greatly appreciated. I've asked gardening magazines without luck.. Thank you for any help you can provide. Ed
Re: Fertilizer Spreader problem
The farmers solution
1. Get a soil test to see what your need. Available at Extension Office. On form say you are fertilizing pasture.
2. Go to where farmers buy fertilizer and get something that satisfies what the dirt needs.
3. Pour it in a bucket on a damp day so you can see foot prints.
4. Scoop up a hand full and sling it while walking. Adjust walking rate to get about what is needed spread. I do 3 acres this way so don't tell me about it being difficult. Keep track of how far it slings so you know where to lap on the return course. Implementing #2 will save you so much money that it matters not if you get 25% too much on the grass.
5. Don't do #4 until the weather cools in the fall, where ever your fall is. Here in TN I would wait till late September. Repeat in the Spring.
Or skip 1, buy a bag of urea and sling it on at a rate of 25 pounds per acre from time to time until the grass becomes dark green. Don't apply unless rain is forecast (the reasons has to do with how it works which I can explain if curious).
If it is already dark green go work in the shop as steps 1 to 5 are a waste of money.
Re: The farmers solution
Basil
Did more than a few acres that way years ago. My daddy had cheap labor....me.
Oh, and the only machine International Harvester made that they wouldn't stand behind was ....a manure spreader.
Kevin French
Barring all that, better to set it a too low setting then too high.
Put it in the middle and go for a walk.
But then again I haven't fertilized in years.
Convert Yourself
Farmers notwithstanding, it should be easy. Your bag will tell you how much it will cover and and should give you the rate in Lbs. per 1,000 sq ft. Measure out a 1,000 sq. foot (25'x40') area, set your spreader at it's 25% setting, and walk the marked off area watching the diminishing amount in the spreader. You can tell about half way through how your doing. If you have material left, weigh it, and you'll have what you need to adjust the spreader opening. If you run out before you've walked the area, measure the space left and that will, likewise, give you the proportion you need to reduce your openings.
