Samantha's Dresser 14-installing the pulls
Drilling holes in a drawer that has hours of labor in it is not a place to screw up. I am installing Lee Valley brass pulls on this piece and they are screwed on with 3" centers. I bias the pulls off center as the drawers get bigger and lower in the case. Starting with the top pull centered the off set increases at each drawer to be above center 3/8" at the bottom drawer.
A fool proof way of locating the holes is show as follows. I set one square for the distance in from the end of the drawer and another for the distance above the bottom and mark with an awl. The second hole is located with a divider set to the hole spacing, in this case 3".
To ensure I get the holes perpendicular I drill them on the drill press.
