wing viens
wing viens
wing viens
Jack Putnam
I still need answers on the same project that I have asked before. Only this time how do I find out when drawing a wing pattern for an insect how do you match up the veins on both sides of the pattern for one wing? When one side has been drawn you flip the pattern over how do you match the veins on the other side to match the first side? I am using thin birch plywood for the wings. Is there some kind of registration marks to be used?
Re: wing viens
print it out on transparency film
Dick Coers
Then you don't have to flip it over. Cut the outside to the shape of the wing, trace over the veins, move it to the bottom in the same orientation, and trace again. You can see the veins in the transparent plastic film, so same orientation all the time. I guess that is what you are trying to do?
Re: wing viens
Re: wing viens
Keith Newton
I like Dick's suggestion of printing onto a clear medium.
As for indexing marks, I assume you are transferring the pattern before any cutting. If so, I would suggest maybe using pushpins out near the corners. You should be able to push them all the way through, so when you move it to the other side, you can just insert the pins through the same holes on the opposite side.
You might want to use some tough tape to reinforce the pin spots.
I'd like to see what you end up doing. I've got lots of dragonfly images that I keep thinking I should start working into some of my turnings.
