A55 Smoothing Plane
Update on bending alum. casting - Success!!
Tim Greif - West of Chicago
Back in March, I asked if it would be possible to bend an aluminum casting, namely the fence on my 12" Makita CMS. That fence had somehow taken on a slight concave orientation. It was pretty noticable when making straight cuts since the wood had a gap at the fence right at the cut line.
Here's the original post: Original Post
I took Sophie's caution about twisting the casting and clamped both ends flat on 2x4s with a gap that I could pull the curved end of the casting down. The pics below show the setup. I slowly cranked the middle clamp down to over-bend the casting in the opposite direction, using small tightening steps over a few days. You can see in the second pic how the casting was stressed from concave to convex. I then left it that way for two weeks. I unclamped it a couple days ago and let it sit to see if it would stay straight. It is now back to dead straight. I remounted it today and I no longer have a gap at the cut line and the 45 angles are dead on in each direction. Saved myself about $60. I love it when a plan comes together.
Re: Update on bending alum. casting - Success!!
Cool!
Only you can answer
Gary Smyth
First. Good on ya. You did what you set out to do. It's as you wanted. Congrats!
But I am curious. That item has been "locked up" for part of March, April, May, June and most of July. Was it worth $60 to have the tool out of service for at least three and maybe four or more months? Don't take offense. You took your time and it worked; and I'm temped to say I would have tried the same thing, but the risk was great that casting might snapped with the next turn of the screw. IF that happened you would have lost whatever time you had in and it would still have been $60 for a new one. Of course if you had a alternative for the work its a whole different matter, but for less than $4 a week.... and to not have access to the tool. I mean no harm, just wondering.
Re: Only you can answer
No offense taken, I understand your thoughts. I actually continued to use the saw for the entire time between March and early July. I typically use it only for trim work and picture frames, but I had it at my river house for the spring and summer for some wood projects doing general crosscut tasks. I use an old Crarftsman RAS for all crosscut work at home. Since I was going on a motorcycle trip in July, I decided to take advantage of my absence to allow the saw to sit idle while the fence was coaxed back into plumb. Thanks for your comments.
Rick L
I've done it on many cast iron jointer fences
My experience, with a different bit of aluminum - the sill on an aluminum-clad window - was similar. I propped the ends of the window up on blocks and set a bucket full of bricks on the center of the sill. After a month, it was straight enough for the window to close and latch.
Electricians know, from bitter experience*, that aluminum "creeps" under pressure. Your approach took advantage of that fact.
*When aluminum was introduced for residential wiring, a lot of fires happened because the aluminum wires would creep under pressure from the screws and loosen, leading to high resistance and arcing, leading to heat, leading to fires.
More on aluminum wiring.
An additional factor with the aluminum wiring that contributed tot eh creep was the heating and cooling that occurs in the wire when it is put under load and then turned off. The wires would heat up when amps were drawn and expand and then shrink. This caused them to squirm. The heating also stretched the screws, loosening the connections. The looser connections added to the arcing and resulting heating. Also, aluminum oxide is a poor conductor and as it crept into the connects, they got hotter still from the resistance. At least, that's my understanding of the problem. There were two generations of screws that improved the connections.
By the way, great job on the casting. I would have tried to fix it. My Pack Rat/ Fix It gene would not have allowed me to live without trying.
