suggestions
suggestions
suggestions
Gary Smyth
In the process of duplicating a medium size business sign approx. 30" x 40".
The sign will have contrasting and different color painted text, some cut out letters, and a three dimensional element that will be screw attached. The base is 1/2" paper covered MDO.
The painted lettering is 2" high, straightforward with minimal serifs, but lots and intricate, with many hard edges. I do not want to mess up the field with a smear if an error is made when painting the lettering. What is your opinion about covering what exists now (field and border) with a intermediate layer or two of wipe on water base crystal poly to 1. add a bit of depth, and 2. enable me to wipe up more easily a errant letter line by separating what exists in the pictures from the new paint to be applied.
What is on now is latex and even though it's been on a week, the heat and humidity here leaves me a bit wary as to its complete dryness. Still, I must push on. I'm open to suggestions. By the way, I tested spray Krylon fixative and it worked great on the small test piece, but this sign is too big to get an even spray of my larger area.
Re: suggestions
Re: suggestions
Before you apply on top of the latex, contact the mfgr. and ask about adhesion issues. Time was you couldn't put anything over latex but more latex. If this going to be weathered (exposed outside), you'd best make sure you've used coatings that are so rated.
Re: suggestions
Re: Indoor or outdoor?
Gary Smyth
Indoor -- all sides, reception enclosure with exposure to moderating temperature and humidity from exterior doors opening and closing four seasons. No direct weather. Think as if Wal-Mart, Sam's Club, Costco, Ikea cart pick up area at entrance to store.
