Doors for dust collector shed?????
I have my dust collector and Air compressor in a closet/shed on the rear of my shop. It about 3' by 8'. Am going to put doors on the shed. It occurred to me there will need to be plenty of room for the air to exhaust out of the shed. Its a Delta DC with a bag on the top and I think its rated at 1100 cfm. I'm sure it seldom moves that much, but I don't want to restrict it. Was thinking of bypass doors made of some Western Red Cedar 1 x 6's I have. What would you suggest as a method of incorporating vents. Space the boards apart and put screen over the cracks? Design in some openings with lattice over them and screen. The shed has been in use for years without doors, so the weather is not an issue.
Re: Doors for dust collector shed?????
Dick Coers
Solid doors, just open them before you go in the shop. Or, arrange the cedar like louvers.
William Duffield
It would seem to me that you would want to put the vents between the shed and the shop, not between the shed and outdoors, so that you don't throw away all your heat in the winter, and all your air conditioning in the summer.
Don Evans
More to consider than just that. The collector will work much harder if it must pull air out of the shop with no way for that air to return easily. So what will happen is replacement air must get back in the shop some how and that will be by way of cracks around outside doors or even worse down a chimney if there is one in the shop. If latter is case and you have a fire going it could get interesting quickly.
As far as vent for doors etc you can purchase just the grills for that purpose at the big box stores like Lowes and those other guys.
My cyclone is in another room also but it has much better filtering on it that bags and I put one of these metal grills over hole cut in wall between shop and room for collector, works great that way.
The fact that you have bags and your compressor in same room also is of concern, be sure and back blow the comp filter often.
I started with a bag unit many year ago and they leak like a strainer, mine was a Delta 1200cfm supposedly. But it was a leaky thing after about 6 months of use.
Don
Thanks, Good thinking....
My shop is in the garage and the garage is pretty leaky. Also, I have a cat door through the garage door that is nothing but a loose flap of plywood hanging in the opening. When I turn the DC on, it opens the cat door. Seems to work well. The air flow is from the door to the machine and out. So it does not really suck ALL of the heat or AC out.
I don't have a flue anywhere near the shop and have nto had a fire in the fireplace for twenty years. As a Home Inspector I was well aware of that one.
I had not really considered how much impact the DC would have on the Air Compressor. The inside of the closet is pretty dusty. I think I will put a huge over sized filter/cover on it and try to keep it cleaner.
Thanks for the thoughts.
