OT: electrical outlet that won't let go?
Jim in N. Va
OK, so maybe (likely) I'm crazy but have to ask...what's going on here?
I went to unplug a lamp in my shop (just to move it) that was plugged into a standard 15 amp circuit. Pulled and pulled on the plug, but could not get it out. Weird! But the plug was small and I figured maybe I was just not getting a good enough grip on the small plug.
So, I whipped out my pliers, gently grabbed the plug (only on the plastic part and not hard), tugged hard and out of the outlet it came. Along with a blue spark flash and a whisp of smoke! (Enough to leave a small smudge on the outlet cover.)
Circuit breaker did not trip. The outlet tests that it is wired correctly. All wires are tightly connected to the outlet and no signs of arcing or anything else in the box. The light's plug is not polarized.
Never had an problem with this outlet, circuit, or light before. Ever.
What may have caused this to happen? And why was the lamp's plug seemingly being grabbed by the outlet?
Thanks for any thoughts.
