Blow down trees
TomD
So we finally got our power back after 12 days. As it happened, one tree fell down in our field, and the only other trees that fell were the 6-8 that fell on the line. When the power guys came in, they had foresters with them who cut a few trees so they wouldn't be in the way of the lines. Now we have a whole pile of trees, a few of which are big, that need to be bucked, there may even be a few boards in there.
My question is that one of these blow downs is resting on three limbs. It is connected at the root ball, and it is resting on the limbs. The result is the weight is over my head in places, and the limbs are under compression.
My plan is to remove some of the free hanging weight at the ends: then either cut the whole tree free at the root ball (standard felling cut area), danger is a big roll in the log as it pivots past the limbs, or I could end up with the tree not moving at all, at which point my situation would not be better, but I would not have anything controlling the main weight from rolling as I make further cuts; or try a few cuts into the supporting limbs and hope gravity takes over (no rush); or maybe keep removing weight from the end, and just keep moving back to the base of the tree, though at some point it could spring up pretty violently.
All of this is over my septic, so I can't bring in a tow.
Any ideas?
