French Curves
French Curves
French Curves
don stephan
I have two sets of French curves from Staedtler, and the templates are all different. I've never been able to learn - is there value in having more than one set of curves, or are the included curves essentially the same between sets?
Re: French Curves
Re: French Curves
TomD
Glad you asked, since I went to wiki, and your answer is there.
There is a large set, and a smaller set of 3. The smaller gives you a shot at parabolas, elipses, and hyperbolas. More here:
http://en.wikipedia.org/wiki/French_curve
Re: French Curves
Re: French Curves
BrianMonumentCO
I have always looked at the existence of multiple french curves to yield a greater possibility of finding a curve that matches my needs. In my eyes it is that simple.
Re: French Curves
Re: French Curves
Ralph Lipeles
I have 6 or 8 in a box that I used maybe 50 years ago. There are many different styles and sizes available. If you do a lot of curve fitting, the more different curves you have, the better your chances for finding a good fit.
Re: French Curves
Those are like training wheels for a bike.
Keith Newton
They would just slow you down, if you can draw without it.
Re: French Curves
Not entirely...
John in NM
The were useful for mechanical drafting, when that was done by hand with pens on vellum. Neatness was far more important than speed. All mine still have layers of masking tape on them to keep the ink from wicking underneath :D
Hard as it was to make a good curve out of segments using French curves, it would be all but impossible for most draftsmen to produce professional looking results freehand.
For any other application, I tend to agree with you :D
Re: French Curves
There are lots of sets of curves
Gary Smyth
and they can get pricy. When K&E was in business they had a flexible curve (segmented) rules from 12" to 30" and French curve set that consisted of 28 curves numbered 1 -29. Number 28 for some reason was not included. There are sets of radius curves (often called railroad curves) that are in sets of 50 from 1 1/2" to 200". K&E made them and I think that there were sets also in degrees and inches, There were "ships curves" and true ships curves are harder to find. These came individually or could be had in a set of 121 curves in a wood box. I have a catalog from 1930 that lists that set at $84.00. I recently saw on ebay a incomplete set of 80+ for $300.
I find the drafting curves very helpful to get a "fair" line in a drawing. I don't have the skill with cad or even sketchup. Bent sticks and pencils bound by a string never follow the same line for me. You probably won't use the template curves often, but when you need them you need them. They don't take up much space keep them.
Re: French Curves
I disagree *LINK*
Dick Coers
I too was a draftsman and was trained on the use of french curves. I can't imagine that anyone can free hand a fair curve through fixed points. Sure you can sketch for a while and get a close fat line, but you are then going to need to true that cut curve with a compass plane or block sanding. I see those TV woodworkers cutting to fat lines, chalk lines, or multiple pencil lines next to each other. It makes for sloppy sawing and a poor curve.
I bought a set of oversize curves several years ago to compliment my drafting tools for woodworking. I sure can't remember where I bought them.
Besides french curves, there are also ships curves, flexible curves, railroad curves, highway curves, and drafting spline curve with weights. Probably more that I don't know about.
drafting supplies
Re: French Curves
Re: There are lots of sets of curves *LINK*
William Duffield
Drawing fair curves in SketchUp is a lot easier if you install and use BezierSpline, a free plug-in you can download from sketchUcation.
http://sketchucation.com/forums/viewtopic.php?t=13563
Re: French Curves
Sorry if I ruffled some feathers.
Keith Newton
That was a sort of tongue in cheek remark. I think I still have a few around that haven't seen use since the seventies. I guess I could be described as someone who doesn't always color inside the lines, but I guess I just always had a harder time trying to use them, than trussing my eye, then taking care of fairing my curves while doing the actual work.
Re: French Curves
Re: Those are like training wheels for a bike.
I still use them occasionally, worked as an Engineer for neigh on 40 years, so have done a bit of drawing in my time. The French curves do allow you to view the results before you put lines on paper as mine are transparent. I think you can do a better job using them (even if you can draw a little!).
Re: French Curves
Re: Do they really work?
TomD
Sure they do, good info. But I was wondering if they ever got the ships curves into reasonably priced cad. Even in posts as recent as 09, guys say they didn't get the right curves. It could simply be that there isn't demand.
My ships curves get used a lot in the shop for orientalizing designs, and various other activities
Re: French Curves
Larry, Dick, and John, I'd like to see how you
Keith Newton
I'd like to see how you have used these in the shop. I understand when you were selling lines on paper for a living at whatever scale you were using in your drawing. But I would like to learn how you guys use them in the shop?
Re: French Curves
William Duffield
I thought the guys who really laid out curves for ship hulls usually used a straight grain cedar or spruce batten and a bunch of ducks (which are usually in the shape of whales, go figure).
http://www.amateurboatbuilding.com/articles/design/vdesign/images/ducks_350.JPG
http://static.rcgroups.net/forums/attachments/7/0/3/8/0/a2914553-240-Lofting%20Ducks%20in%20Use.jpg?d=1260062428
Don't let the gold fool you. They're cast from lead.
http://www.westlawn.edu/news/EdsonSplineWgtsWEB_files/image004.jpg
Re: French Curves
I did mention...
John in NM
That for any use outside drafting, I'm going to agree with you :D
My French curves are all packed away in a box with my Leroy set and pens :D
In the shop the curves are usually large and I do them with a flexible stick or by eye. Or for elliptical curves, with two nails, a string, and a pencil.
Re: French Curves
Shaker candle stand feet
Dick Coers
One of the times I used them was to lay out the legs on a shaker candle stand. I used an oversize top, and didn't want to use a constant radius. The french curve allowed me to get a pleasant radius from the flat that came up flush with the center post, curve nicely, but allowed a sharper radius to look perpendicular to the floor. I cut a pattern first. Without the french curve, I would have had to play with lots of different radii and then try to blend.
Re: French Curves
TomD
I still have my set from when I was at YDI. They sure are lead, so the paint peels off, and I have masking tape over the bare areas now.
I also have a small set of ship curves, and they fall right in place on classic boat plans. So they did you them for a lot of stuff.
Re: French Curves
my hand is up
I have a large set of these curves, remains from my days of drafting and drawing figures for publication. I can't draw. I accept this and many other limitations I have when it comes to design and building furniture. If I can find a crutch or training wheels to accomplish what I don't have the talent or experience to do otherwise, I will shameless employ it. May objective is to make stuff as best I can with little concern for how.
The simple answer is that I use them for drawing curves to be used for molding or feet or other decoration on furniture. Anything you see curved on the attached examples was done with French Curves- feet , moldings, trim. I have never had anyone ask if it was done with a French Curve or free hand.
Re: French Curves
Gary Smyth
I found this "pod" in a box on a shelf at a Going Out of Business Hobie Cat sail maker's loft. Approximately 5" long, 2 1/2" high, and 1 1/4" wide and 1 lb. each. I got nine, some other guy got 24 similar. These are cast iron. I was going to drill for a bent pin, but so far no need and they don't get tangled when in a bunch. The originals are bronze and weigh about triple. A company named Edson Marine http://www.edsonmarine.com/marinestore/index.php?main_page=index&cPath=108 still makes original look ones at $46/ea. or six for $250. The flukes of these are that of a fish, and not a whale, but they were used as weights when laying out fabric and temporarily holding hems and grommet locations on the loft floor. Not antique but less than 1/7 the price of the original bent pin type used in earlier times. For me these come in handy when laying out full size rolled paper or any other occasion where a light hold is required. By the way.If interested, there is a site of making original looking whale splines of lead. http://forum.woodenboat.com/showthread.php?164653-Making-Spline-Weights-aka-A-Pod-of-Whales
Re: French Curves
Re: Larry, Dick, and John, I'd like to see how you
Don't have a picture, been quite a while since I built it, but last time I recall using the French curve was for kind of a scroll work pattern on the runners between the feet of a chest. Wanted some kind of decoration on the bottom so used the french curve to lay it out, band sawed to near the line then used drill press and circular sanding wheels to finish to the line. Although I did a lot of sketching prior to drawing, I certainly wouldn't want to try to draw a finished item freehand. I cannot claim to have any artistic ability. As I recall, I also used the french curve to layout some feet for a project.
