Craftsman plunge router
Joseph Mulherin, sr
A bearing has gone sour inside and I need to remove the head of the motor to replace it. BUT, the screws holding the casing are so tight i cannot get them to release. Have tried "lock-ease" and some other tools to get them to loosen but no effect.......help please
Re: Craftsman plunge router
Re: Craftsman plunge router *LINK*
Bob Entwisle in NJ
Hi Joesph,
My penetrating oil of choice is Kroil. It's far and beyond any other penetrating oil I've used for freeing up stuck parts.
I've heard, but not tried it, that a 50-50 mix of ATF and Acetone is also good for freeing up rusted parts etc.
Bob in NJ
http://www.kanolabs.com/
Keith Newton
Have you tried an impact driver yet? Or are you just using a hand held screwdriver?
Joseph Mulherin, sr
Yes, Keith, I have tried the impact screw driver...and the lock-ease. Am going to mix up the ATF and acetone and see if that works. Bearing only costs about $0.60 and I do not want to take the router to some repair shop for such a measly problem.
Keith Newton
I understand I just changed them in my Makita 3612 last week. Sometimes heat will do a good job on loosening them. You could try a soldering iron, or micro torch an old bit while it is in the grooves.
Howard Norman
My standard penetrating oil these days is the 50/50 mixture of ATF and acetone.
Joseph Mulherin, sr
Tried it and it did not budge, so I am drilling out the screw head to get the motor head casing loose, will unscrew the remaining screw in the body and replace with a longer screw with a nut on top to reassemble after installing the new bearing
Joseph Mulherin, sr
Ordered two new bearings....now just have to figure out how they are removed and then I shall reassemble.
It is a good router and I use it in my rockler table top effectively. Just need to figure out how to keep the dust from getting to the bearings again...some sort of shield will be made inhouse.
Joseph Mulherin, sr
Tried to dismantle and found it was too delicate for this old man to do, so I am taking it to the Home Depot store in Palm Springs and Larry will do the work of replacing the bearings for me.
Joseph Mulherin, sr
Reason that it is going to the shop is that the bearing is gaulded into the casing and some has melted down inside a little and is not readily accessable for me to do here at home. Profession help is needed...will cost some but the router is a good one and has done much work for me over the past 8yrs. Need it in the Rockler table to work on my future rocking chairs.
