Ryobi router adjustment
Jerry Gibbs
I was given a Ryobi router with three bases. The router had been in one of the fixed bases and in a table for probably 2 years. The router adjusts the depth or changes bases by loosening a clamp and twisting a adjustment ring. I cannot move the adjustment ring (which may move the whole motor). I have blown out what I can with air and tapped on everything with a mallet. Any suggestions are appreciated. Jerry
Re: Ryobi router adjustment
Liquid Wrench?
I have an older Rockwell router, the consumer version of the Porter-Cable 309 trimmer but with a larger base, on which the adjusting ring shrank somehow. In order to get movement, I actually had to cut it and reglue it (can't now recall the glue I used). You might see if the adjusting ring is still available, if you find it's hard to move even after you get it moving.
Jerry Gibbs
was able to move ring with some heat. ring adjustment works with great difficulty. terrible design. Jerry
