System 3 Epoxy
Yonak
I've never used it but I see it mentioned frequently. I'd like to try it as a wood filler but I have some questions.
Is it easily sandable .. say, as compared to hardwood ? Will it sand clean off a smooth wood surface or does it leave a stain on the areas beyond the gap to be filled ?
Does it come in colors or can it be colored with, say, a coloring agent that is designed for it, or with paint (I assume oil-based) ?
I notice there are several buying options such as different quantities, a thickening agent and a drying agent. (Maybe more.) I believe I understand the usage of the drying agent and I don't think for my application it will be necessary. As for the thickening agent : the gaps I will fill will range from 1/32" cracks to pea-sized voids. Would a thickener be suggested ? Are there different thickeners ? I'd like to be able to spread it on with a putty knife and have it go deep into the crack (so fairly thin, but filling).
Finally, size : I intend to try it out for a project mixing a quantity, probably, a bit smaller than a ping pong ball and then if it works, get larger quantities for regular use. What is the recommended quantity to buy ? The quart seems pretty large if it turns out not to work as well as I hope and maybe there's a smaller size. Is there a kit available that would contain all or some of the items I need or should I get everything individually ?
Thanks for any replies. If this works out I would be using this product quite a alot. Maybe there's another epoxy brand that would be better or is System 3 pretty much the best ?
to transform them into unique features
