5mm router bit, where to find
Richard McComas
I need a router bit that fits my Dewalt 611 (1/4" shank) with a 5mm 2 flute straight or spiral design with a 1'' cutting length.
This is for drilling shelf pin holes.
Richard McComas
Re: 5mm router bit, where to find
don stephan
Not sure of the cutting length, but when I used to do this I found 5mm straight bits at Woodcraft. Don't know if they were made by Freud, Whiteside, or private manuf.
GoTo WC Marketplace
Click on Woodcraft, put metric router bit in the search box. They have them, and WC gets the benefit.
Another option,
Keith Newton
Back in the mid eighties, I made up a bunch of drilling templates to use with a plunge router. What I did, was to have about 200 1/2" to 10mm bushings made up, then bonded the standard carbide brad-point drills into it to use in a 1/2" plunge router.
This works great. I can drill 1.5 holes per second, or 90 per minute, on long runs. Sorry, I don't have any to sell, I'm down to my last 2.
The cheap easy solution
I have drill templates made by drill press drilling 1/4" (my pins are 1/4") a line of holes in a piece of 1" poplar. Some are 2' long ranging to 7' long for closets. It doesn't matter if they are precisely spaced as they spacing in the cabinet will be identical. I index this template off the bottom of what ever it is that needs shelves and cordless drill the holes. I have done hundreds in furniture and closets and cabinets. Could be readily done with 5 mm drill.
One can probably get a 1/4" x 5mm end mill at any machine shop supply.
Template
I take a piece of scrap and drill 2 holes with the given interval positioned from one edge of the scrap. I then glue a dowel in one as a peg. With a fence on the drill press, I drill the first hole the put in the peg to precisely locate the next hole, drill through the 2nd hole , and so on and so on. Spacing is perfecto.
Of course, if you use 5mm, you'd need a 5mm drill and a 5mm peg.
John McGaw
I can't remember where I bought my last one. Amazon sells one by Whiteside that has a 1/4" shank and one by Festool with an 8mm shank, both standard collet sizes but neither bit is cheap by any stretch of the imagination. I know that I didn't pay that much for mine -- probably half that.
Re: Template
don stephan
My experience is that drilling through the same hole many times enlarges the hole. I drilled a guide hole to fit a standard router bushing and used a plunge router, so that the diameter of the guide hole stayed constant.
Re: Template
Bill Howatt
I've never done this but I'll throw it out in the FWIW category.
I have heard of peg-board hardboard stirps with the large holes being used for such a template because the holes are uniformly spaced. Hopefully the hole-size would be OK.
Bill
Re: Template
Bruce, a MN Galoot
I use the same technique and have kept that template for 20 years. It sure speeds things up. Plus, the holes you get with a router are much better. On the last project I did, though, I found that my single-flute spiral router bit wasn't quite as accurate as a double-flute bit.
Richard McComas
Thanks for all the replies. I have my template under control. I have my router and router bushing under control. If fact I've been shooting 1/4 inch holes for a while now. I was just looking for a source for a bit I could make 5mm hole with that fit my Dewalt 611. Thanks again.
www.routerbits.com
