vein transfer
vein transfer
vein transfer
Jack Putnam
I am working on a project that is carving out a mayfly it's a flying bug that trout love.The body is 6 inches long with legs and the wings are 1/32 of an inch thick made of birch plywood which is very thin. The problem is what is the best way to transfer the veins from the picture I am copying from to put onto the birch plywood. I tried transferring the veins from the picture to acetate then cutting the veins out of the acetate then laying the acetate down on the birch plywood but it didn't work. I want to be able to use an airbrush to spray the veins from the acetate or what ever I can use onto the birch plywood. I don't want to cut out the picture I am copying from and glue it to the plywood it just wouldn't look good.
I have never tried this before so it is very nerve racking. Any help would be appreciated Thank You.
Re: vein transfer
Re: vein transfer
Keith Newton
Someone on this forum made the suggestion for a similar project , to make a new printer copy, then lay it the wood which has just been coated with Purell, hand sanitizer. I think it may be the alcohol that lifts the ink and makes the transfer.
Re: vein transfer
Re: vein transfer
Lee Schierer in McKean, PA
If you have access to a laser printer you can print a B&W copy of the photo, cut out the wings and transfer the veining to the wood with a hot iron. The black powder will transfer to the wood.
Lee
Re: vein transfer
Re: vein transfer
Ralph Lipeles
Go to a stationary supply store and get some carbon paper. You put it between the sheet with the item to be copied and item to receive the copy. Then move a stylus along everything to be copied and the carbon paper will transfer the stylus tracings to whatever the carbon paper sheet rests on.
Re: vein transfer
Kneale Brownson
You want transfer paper and a hot iron
Kneale Brownson
Print your image in reverse on the paper with an inkjet printer and use a hot iron to transfer the inks to the wood. Same process with wood as with fabric.
Re: vein transfer
Re: vein transfer
William Duffield
The guys who carve bird decoys with realistic looking feathers burn the feather details onto the wood with a wood burning pen. I don't know how well the skill would transfer to birch plywood, but it might be worth experimenting. They prefer to use tupelo, because it gives them the best control and definition.
