Veritas - Innovation in Tools
OT - Electrical help needed
Ray Carson - Lawrenceville, NJ
Now that everything seems to working properly with my WC account (thank you all, esp. to Bill Houghton) I can post my question. It was an ID10T error. :D
I've been busy lately renovating two bathrooms at once in my home. I guess my mind is fried (pun intended) after all the framing, sheet rocking, plumbing, electrical, painting, trim work, etc.
I have a light over the sink in one of the bathrooms that I cannot get to work. I know that it's simple but like I said, I just can't wrap my head around it. I think what's messing me up is the 14/3 shown in my diagram. The 14/3 is there because of a previous layout that has been changed. It was too much work to remove so I decided to repurpose it for the simple light switch circuit shown.
Everyone here at WC hasn't let me down in the past with electrical questions and I'm hoping ya'll can help. See attached PDF.
Thanks, Ray
Re: OT - Electrical help needed
Jason Roehl in Lafayette, IN
There are essentially two ways to do it, I'll describe the way I would.
Connect the black (hot) feed to the black of the 14/3, as well as the white to white and ground to ground from the feed to the corresponding wires in the 14/3. Cap off the red on both ends.
Run another 14/2 from the switch box to the light. Connect (on the light end) black to black, white to white and ground the fixture wherever a ground screw is available. In the switch box, connect the white from the 14/2 to the white from the 14/3. Do the same for the ground (run a scrap piece of ground wire to the switch if it has a ground screw from this wire nut connection). Connect the black wires from the 14/2 and 14/3 to the switch (on different screws, of course).
Jason
Keith Newton
The reason for the 3 wire, is to use two switching locations. Can you still get to that switch box? If so, when you flip it, the current goes back and forth between the red, and black wires going to the other switch.
I am assuming you are going to move the light over to the box and install it where the "feed" wire come in, right???
Basically, you can ignore the red wire and cap it off on both ends and then treat the connection as if you had 14/2 with ground. Connect the black in the 14/3 to the black hot feed. Connect the white in the Feed cable to the white on the fixture. At the switch, connect the black to the line (top) screw on the switch. Connect the white wire in the 14/3 to the other screw on the switch. (you should use black tape to cover the white wire, "converting" it to a black/hot wire or you can color it black with a Magic Marker.) Back at the other end of the 14/3 convert the white wire to black and connect it to the black wire on the fixture. Connect the grounds together in the hot or feed box and most fixtures now have a ground on them that should be connected to this ground. The switch should also have a ground lug on it and you can connect the ground in the 14/3 to it.
An alternative would be to ignore the white in the 14/3 and use the red for its function. Since red is also a "hot" wire you would not have to convert it by taping it or coloring it black.
I was thinking along the lines of your two Barry. Thanks.
All fixed
Thanks everyone. I just had to take a break from it and come back to it with a fresh mind ..... and a little help. :)
Wayne Goldstein
Ray,
After you get the circuit working be sure the power is provided by a 15 amp circuit breaker. The 14 gauge wire you are using and will create a fire hazard if used with a circuit breaker larger than 15 amps.
Wayne
