Kitchen sink magic,,,,,,, uh, physics.
Keith Newton
I thought I would share this, knowing that some of you have kids or grands that you'd enjoy sharing something so simple and easy with.
Question, how can you suspend an egg off the bottom and sides, in a cup of water, without touching the egg with anything except the water.
Last night I boiled 6 eggs, and forgot to start a timer. After what seemed long enough, I scooped one up in a one cup measuring cup to sample, then held it under a cool stream from the sink faucet. I was a little surprised to find that the egg rose off the bottom, and would stay more or less centered under the stream even as I moved the cup around, even at times to rise slightly above.
It took me a moment to realize what was happening. This is and excellent example of how the pressure drops due to laminar flow of gas or liquids over a smooth curve such as airplane wings, or sails on a boat.
I wouldn't imagine that it would matter if the egg had been boiled, or was raw, but size of container does. I couldn't get it to happen in a large deeper pot. Also, my faucet doesn't have an aerator, which probably would interfere with the smooth flow. My cup measures 3.25" x 1.75", so this may be another of those times when size matters. I suspect that the turbulence under the egg, as the water hits the bottom of the cup would increase the upward pressure.
It takes a little playing with it to appreciate and or understand how it wants to stay centered under the stream. If you move to one side, the greater flow on that side, equals a greater drop in pressure on that side, so it follows the stream.
