Veritas - Innovation in Tools
glue turning black
glue turning black
glue turning black
Brad Bransky
Many years ago if I had a small opening in a miter or a bit of a knick around a pinned mortise, I would put a tiny amount of glue and some of the same wood dust as the project and the knick or chip would virtually disappear.
I quit wood working after a bypass about 8 years ago and recently started again. I started using Titebond which turns black in miters when I use it the same way. I've tried red, blue, green, basically all the popular ones.
Could it have been Borden's originally. Whatever it was, it would dry clear. It wasn't Gorilla Glue.
Thanks,
Brad
Happy 4th. and be careful!
Re: glue turning black
John in NM
Try some hide glue. Technique works well with hide glue. It does shrink quite a bit though.
I've never had any luck doing this with PVA glue like tightbond. Never can seem to keep from it going dark.
Dick Coers
I always thought Original Titebond dried clear. Try white glue, or rub in the sawdust and a drop of thin CA glue. Don't use accelerator or it may go white. I also like Famowood filler for hairline cracks. I use masking tape on both side of the problem area so the filler just fills the problem, not the pores around it.
Lee Schierer in McKean, PA
The only time I've had glue turn black is when it makes contact with iron. Oak will turn black when wet and in contact with iron.
Lee
William Duffield
Maybe you have a different water supply? I've had problems with woods with a lot of tannin in them turning black from the very high levels of iron in my water supply. I have to buy water for raising grain and wiping glue off, but I've never had problems with straight TiteBond and oak, if iron was not involved. I also don't rub out finishes on oak with steel wool. I use synthetic 3M or Norton instead. Brass wool also doesn't give problems. You're not dispensing your glue in a steel container, or spreading it with a wire brush, are you?
Your problem might be spreading the glue with an acid brush. I've had the steel handles rust if I wash them out and reuse them.
Brad Bransky
Can'figure it out. Water good, only use steel wool to buff shellac on quarter sawn white oak prior to waxing,
Tried Elmer's last night-same thing. Idea just popped up. I haven't been working with white oak for awhile but with walnut, cherry, cedar, and maple. Perhaps there is something about the WO which doesn't let it turn black. It'll check it out later.
I'd like to know if others have this problem.
It'll get back. Thanks for the feedback.
Brad
A picture might help us
something doesn' t make sense
Titebond is light yellow and it dries to a light yellow solid. If it is turning black it is because of something you are putting into it. Look there to find the source of black.
Sgian Dubh
" ... Water good, only use steel wool to buff shellac on quarter sawn white oak prior to waxing,
Tried Elmer's last night-same thing. Idea just popped up. I haven't been working with white oak for awhile but with walnut, cherry, cedar, and maple. Perhaps there is something about the WO which doesn't let it turn black."
There's iron getting into the mix somewhere Brad. Iron, water and tannin equals black. Of the woods you named the one with the highest tannin content is white oak followed by walnut, and even cherry has some tannin it and all will react with ferrous sulphate (a well known colouring agent in wood finishing) to create something in the blue/grey area of the spectrum. Maple too reacts with ferrous sulphate to create what's called harewood or greywood. I've never applied this chemical to cedar so I don't know how it reacts.
But certainly, as Bill suggests, the contamination leading to the black is coming from somewhere. For example, I sometimes see black stains at localised spots where the steel of sash cramp bars touch the glue squeezed out at edge joints in panel glue-ups, especially when gluing up oak panels, but in other woods too. I'd start by looking at the tools you're using to work the glue into these voids. What are they made of? Slainte.
broadening the description
Ferrous sulfate and every other ferrous and maybe ferric compound as well as steel, and iron in contact with air and water, combined with tannin will make black. Ditto for some other elements too.
Are you clamping on the face?
Dick Coers
Wondering if you use a c clamp, or similar with a bare steel face, on the face of the joint? It doesn't take much contact to set up that chemical reaction.
Re:Agree
I use Titebond 1 as well as 2 and 3. I have glued Cherry, Walnut, Oak, Elm, Ash, Pine, Locust, Birch, Cedar, and some exotics and have never had any of the glue turn dark. I also use a mixture of the sanding dust from the wood I am using mixed to fill defects and have never seen any discoloration. It has to be something you are using as a tool or possibly a mixing bowl etc to cause a reaction with iron. I can't think of any other material / metal that would cause a reaction with the tannic acid from the wood or the polymers in the glue.
Re: Are you clamping on the face?
Brad Bransky
By gosh! I think you've got it, maybe. I've been making boxes and clamping the miters with either clear packaging tape or BLUE painter's tape.
Maybe, just maybe...
Thanks all,
Brad
