OT Follow up on Metal Detecting Adventure
A week or two ago I posted questions about metal detecting. I wanted to find the property pins on a house I am selling. Someone suggested a Harbor Freight model. I am skeptical of everything HF, but since this was basically a one off for me I gave it a try. Got their better unit and tried it. It was DOA. Called their support line and spent half an hour waiting only to be told they would connect me to Tech Support. After another half hour was told, "Oh yeah, we have been getting a lot of calls on those, take it back and get a different one and if that does not work take it back for a refund". Went back to the store and the only other one they had was broken in the box. Got my money back and bought one through Amazon. Came in two days and worked out of the box.
Went to the property and waved it around where I thought the pins were. Not as easy or as accurate as I hoped. I thought I could sort of do X marks the spot by going at it from two different directions. Not nearly as good as I hoped. Found the first pin in about 20 minutes. Measured back to where the second one should be and found it in about ten minutes. It was in plain view, except that it was in a brier patch. About ten more minutes got the third one. Also in site except I was confused by the "Arraingement" of the various Cable and phone boxes. Then went to find the last one, on the front corner. Took a few minutes to determine the neighbors had put the fence on the wrong side of the line. 2 1/2 feet on the wrong side. Back to the first side, it is now clear that the neighbor on that side also put their fence on the wrong side of the line. Anther thing that slowed me down was at the first pin, the neighbors driveway had crept about two feet onto my property. Not really surprising, but the gravel made digging for the pin tough. The pin is laid over at about a 45 degree angle. I'm guessing the cars did that.
The lady that lived in the house before I bought it was in a wheel chair and had some mental issues. I think its interesting that both neighbors took advantage of her. I suppose its possible it was an accident, but I wonder. The fences sure made the process harder. So did the cable lines and trash.
I realize I am unskilled and inexperienced, but the metal detector did not add nearly as much t the process as I thought it would. Now I wonder if a "pinpointer" is a necessary accessory. And Why couldn't I use one of the wands like some of us find nails in lumber with?
