3M glue residue
Jack Putnam
I have asked a question about what type of glue I should use on a project I am working on using PVC pipe and rubber sheeting. I got an answer from Wood central to use contact cement. I made a test using 3M spray glue and contact cement on the PVC pipe and the rubber sheeting. It stayed out side for a month and the rubber sheeting using the contact cement did not come off of the PVC pipe where as the rubber sheeting came off the PVC pipe using the 3M spray glue.
Now my question is what can I use to take off the residue from the 3M glue on both the PVC pipe and the rubber sheeting so I can replace it with the contact cement it has to be clean as possible. Thanks for any help you can give me.
