A little chainsaw fun *LINK*
So you think you are good with a chainsaw? Are you this good?
T.
Chainsaw video
Re: A little chainsaw fun *LINK*
When I was a kid, over fifty years ago, my Dad and Grandfather hired a guy to fell a huge oak in the front yard. the guy studied it a while, took down a single section of picket fence, then climbed a section of an aluminum ladder about 16 feet tall, hooked his leg over the top rung, and with chainsaw in hand, pushed away from the tree, balanced himself on the ladder, and walked it around the tree by swaying left to right and twisting it. He cut off several limbs to balance the tree. Truly was like a circus act. Then he came down and cut the tree and felled it exactly between the fence posts. It twisted as it fell. I knew right then I was completely out classed and would never be able to either walk the ladder or fell any tree like that guy.
Your video was amazing.
Keith Newton
Hum,,,,,,,,, He certainly had me fooled. It looked like he had cut the close side for the hinge, then did his final cut on the opposite side. As the log tipped over, the cut was all the way across, without any hinge left. Good thing a cross-wind gust didn't nudge the top about then.
Exactly
I'll bet that what he was giving thanks for; no wind
parts missing
There were some cuts missing from the video. I could not figure out how the tree was cut. He was obviously using wedges to direct and control the fall but it was not clear to me how exactly they were employed, certainly not the way loggers are being taught today. In any case the way he handled the saw showed he knew what he was doing, in an "old school" way.
When I cut 40 years ago we never used what is today called a "hinge". The focus was on not pulling splinters out of the tree's center as it fell. With the modern chisel chains boring cuts are now practical to cut away the center of the tree before it topples. In the past we just made the first cut go to the center or beyond, sawing bar clearance as we proceeded.
I never cut in a strong wind, but the modest winds we have here were never a factor influencing the direction of the massive weight of the tree falling.....except in one instance. I was cutting a large tall beech that was isolated at the edge of the woods on top of a hill. As I completed the back cut a puff of wind stood the tree back on the stump. There it sat, cut off but balanced with the saw sandwiched between stump and tree. It was the only time I saw the boss a bit stressed. While I was gone with the skidder to get a wrench to remove the saw bar the tree decided to go ahead and topple as it was supposed to. The name of the saw was painted on the saw bar. Thin as this paint was it embossed the saw name on the butt of the tree, what ever pressure that took.
I did enjoy the video.
Re: parts missing
Doug Trembath
When I moved to PA in the early days of this century, I had a lot of experience cutting wood with a chainsaw, as a turner, but felling, not so much. I was on 76 acres of woods, and cleared an additional acre so we had a nice place to have a fire ring. I figured I did ok...
There were a number of big Pines along the driveway, near the roadway, and I needed to drop one so the electric company could install a pole for my new studio's electric feed line. I wanted to drop it over the hill, and figured it was doable. I waited until early in the morning so there wouldn't be any breeze. Cut the initial wedge out, then went to the other side and started the final cut. Got to just about the end of the final cut, the tree started to lean a bit in the desired direction. Just then a small breeze came up, pushing the tree back toward me, freezing the chainsaw bar with no more than an inch wide hinge. It just sat there. >(
Bummer...
The tree was very close to the utility lines, phone and cable, and I worried it may take them out if it fell wrong. Got a bit worried. :\
I went in and telephoned a buddy hoping he could bring some equipment over and push it over the hill, but no dice. Got a bit more worried, said a quick, heartfelt prayer, and went back out front...
The tree had fallen exactly backward of the way I wanted it to go, and fell in the only place it could not hurt anything, gently brushing the 50 foot Blue Spruces that lined the roadway. I hurriedly cut it up and rolled the pieces over the hill, swept up the shavings, and gave thanks to a better sawyer than I had been. :b
Months later I got cocky and dropped another that needed to come down. It twisted and turned, and leaned over onto my tractor shed, taking out a bit of the roof. It was a doozy of a time getting that one away from the shed and into place, but that's a story for another time...
Cost me $600 for materials to fix the roof. I used that tree as a boundary between the garden and the new studio driveway. It's still there, although I have been gone for some time... :D
Doug Trembath
YouTube is littered with...
Tom Dunlap
...felling vids that didn't go right. Its nice to see one that worked!
Knowing how to:
-make an open face
-bore cut
-using gunning lines
-wedges
will all help make perfect falls.
The tree will always fall perpendicular to the apex of the face. All that wedges and angled back cuts do is to help initiate the fall.
It isn't often that I have to using gunning to setup a face cut. When I have done it the results were always as perfect as this video.
I learned about gunning from Jerry Beranek. Some folks may have seen Jerry's famous poster...150' up and its still 7' across!...about taking the top out of an old growth redwood. Bailey's sells the poster.
Tom
what are gunning lines
Never heard the term.
Re: what are gunning lines
Tom Dunlap
There are many ways to gun a fall.
Here's the simplest explanation.
Take your zig zag ruler and open it up with the hinge in the middle...a six footer will give you two, 3' legs. Bend these like a divider and place one end on each side of the tree and the hinged point will aim or gun towards the lay of the fall. Move the ruler around until you get things lined up. Mark the points where the ruler touches and those points become the apex/corners of your face.
Anything that gives two equal legs will work for gunning sticks. There are large zig zag rules...in the pictures they seem to be about ten feet or longer, giving you 5-6' legs. Two measuring tapes work also. If you have string that doesn't stretch that can be used.
Once the apex is marked cut an open face and make sure the apex is clean. then make the backcut as you see fit. I really like doing bore cuts and leaving a strap on the back to trip the fall. This is especially safe when tripping large trees.
tom
I have never heard of it or seen it practiced in these parts. I just use the line on the saw body along with everyone else I have seen cut here. In the logging contests the contestants are about 10 for 12 hitting the can at 30' out. With a bit of care I can do nearly as well.
Tom Dunlap
Yes. The gunning line on the body of most saws or siting perpendicular to the bar will work for poles and simple falls. Jerry Beranek learned his craft felling old growth and second grow redwoods and west coast big trees. When I've needed very high accuracy for dropping a tree in a residential area I'll gun it
No different than using a more accurate measuring device for joinery vrs framing a shed
OT -  Sculpture Art  -  Topping Out
Gary Smyth
Ran across this bronze several years ago. Sculptor a person named Pattelle. Approx. 12" high. Anyway I was told that this was a limited production gift to "top" executives of Weyerhauser in some past time.
By the way, if anyone knows more about this piece or where others may be, let me know.
Humboldt cut
Robin Corell in Atascadero,CA
It looks like he used what is often called a Humboldt cut. the face cut is upside down from what most people are used to seeing. It is a safer way of feeling trees on the side of a steep hill because it removes the edge of the stump which a tree can sometimes pivot on and and change direction. In this case he used a Humboldt cut to insure greater accuracy.
Re: Humboldt cut
Keith Newton
I suspect you are right about that. At first, I was viewing it on the small screen of my phone, and thought the small bare area toward the camera was a notch.
But toward the end, when the tree falls, as it leaves the stump, the end appears to be pretty flat across.
the reason bening the Humboldt cut
The notch on the bottom rather than the top of the cut yields more lumber in cases where the trunk doesn't flare at the stump. The log saw set to remove a slab from the side of the tree with the notch would remove the notch along with the butt swell. For our eastern oaks there is so much butt swell that notching the top of the cut does not shorten the board that is sawed from this part of the tree.
But in the case of this straight sided fir a top notch would would shorten the board cut from where the notch was located. The bottom notch is harder to do because the saw has to be lifted. Personally I have a hard time doing this cut so rarely use it.
I agree with all of that, especially age making  *LINK*
Keith Newton
lots of things harder to do, like the uphill cut part. My knees have made it so painful to work down low.
When I look back at some historic photos of when they were logging the virgin forest around here, they often cut 6 -8' off the ground on hardwoods, and may have a couple of men on top just to show the size.
And then for Cypress, it was even higher. Back out in the sloughs around the cabin, there are plenty of big trees on top of the stumps from that logging, maybe 12' above the normal water level. I can still see the pockets where they chopped a hole for their staging on some of them.
Last night I watched the video below of logging the Pacific NW, just to see what I could learn about how they managed to drag those giant logs around before they had a lot of the modern equipment. It's amazing how much timber they got out back then before chainsaws.
However, back to dealing with the flair, since I'm sawing for myself, I don't worry about shooting for perfectly straight boards to make a perfect lumber stack. I find that it is pretty predictable to find curly figure in those buttresses. And finally I've found the best process for busting down these big logs with my chainsaw, with the fewest cuts, and best yield of QS.
http://www.youtube.com/watch?v=I0K5XwmGmuw
Re: parts missing
Bill White
Being good is one thing. Being lucky is another. Being good AND lucky is a gift.
Bill
Re: the reason bening the Humboldt cut
Actually the biggest reason for using a Humboldt cut is safety for the Faller. Humboldt county is very mountainous and when felling a tree on the side of a mountain it is safer to have the tree fall down hill rather than up hill but that too presents a problem. Since the tree continues falling well past the stump if a traditional cut is used the tree can break the hinge and spin on the stump potentially coming back on the Faller. This is rugged terain and its not always possible to get clear and use wedges, particularly for a guy on a fire crew in the heat of fighting a fire. With the face cut on the stump it provides for more clearance for the log as it falls on a sometimes 30 degree angle past the stump.
Greater lumber yield is a side benefit but it is used purely for safety for the guy on the ground near the stump.
OSHA disagrees with your premise
Excerpt from an OSHA communication,
"During the six-month stay, OSHA met with representatives of various logging associations, including the Western Logging Council, and carefully reviewed the record on the issue. The record indicated that in several regions the Humboldt cutting method has replaced the conventional method, primarily for productivity rather than safety reasons. This is because in Humboldt cutting, as opposed to the conventional method, the notch is made into the stump rather than the log, which reduces the loss of useable wood.
It matters not whether the notch if above or below the hinge or whether the land is east or west. I can assure you that the hollows of the lower Appalachians result in the same tree falling down hill situations as Oregon, except we may be steeper. If the notch is open enough the hinge will hold. If the notch is not big enough OSHA requires the back cut to be above the front cut sufficient to support against kick back.
Western log standards are substantially different from eastern hardwoods and these standards result in the felling differences. Notch above or below are equivalent in safety when properly employed.
