OT. Brick wall
eliot feldman
What would be a fair price to have a brick wall built about 30 feet long, two feet high, two courses thick and sunk into the ground about 6 inches?
OT. Brick wall
eliot feldman
non-local advice useless
Where brick is popular brick is cheaper and masons are aplenty. Go to brick yard and ask for some mason recommendation and get quotes.
Where brick jobs are less common both the price of brick and labor can be much higher.
Re: non-local advice useless
John McGaw
So true. You wouldn't even want to think about a brick wall in Alaska -- shipping them up from Washington puts them out of reach of ordinary folks. On the other hand you see fireplaces made of volcanic stone from Hawaii pretty frequently since this material is nice and bubbly and light.
What is your budget?
Re: OT. Brick wall
ian in Sydney
Not sure for where you are, but here standard bricks are sold by the 1,000, so if your wall needs 4,500 bricks you need to buy 5,000
as to laying them -- local brickies typically charge by the brick.
I've seen rates higher than as $2 per brick -- when building is booming and there's too much work.
conversely when work is tight, rates might drop to less than $1 per brick.
I'm not sure if the rate varies depending on whether the bricks are laid stretcher bond, or Flemish bond, or one of the other named standard ways of laying bricks.
then there may be a loading if your brick work is special -- i.e you're using coloured bricks to form a pattern
I guess what I'm saying is that the all up cost to you will depend on
1. the bricks you are using and where they come from
2. local competition among brick layers
3. whether the local building industry is busy or quite
4. the way you want the bricks laid -- stretcher bond, Flemish bond, etc
5th cost consideration
ian in Sydney
previous post should have had a 5th point
5. the cost of brick wall's foundation -- which around here is a trench containing a reinforced concrete beam
Re: 5th cost consideration
Joseph J Mulherin, sr
Yes, I agree with Ian. Dig a trench 6" wider than the width of you wall; foundation has to be at least 6" deep(thick) with rebar installed. I recommend two 3/8" rebar mount4ed on 2" cement blocks with wires inserted and spacers between the rebars to hold straight. Pour the concrete and smooth level it out, then score the surface with a trowel to make a small groove in the concrete for the mortar to grab hold of when laying the brick. Use wire spacing between the brick to maintain an even level and to strengthen the wall.
