Wood And Finish selections for outdoor furniture??
Well folks, this is a first. A client wants a large dining table for an outdoor porch. It is a covered porch but still vulnerable to the elements. They want a "nice wood" but one that holds up in the outdoor setting. They also indicated they would want to "refresh" the finish annually to keep it nice.
I have made tons of furniture over the years, but this one is a curve ball for me. I searched my wood stash and found some curly white oak. Woohoo! But then I realized I did not have enough. Rats! The client does NOT like oak but they would have gone for that figured stuff. OK....what next?
Teak, purple and yellow heart can work but all dull to grey and not great figure. Ipe is too heavy for a 12 person table.
So what are options for other woods? Can maple work if finished properly?
And speaking of finish...I know marine finishes are tough but are there finishes that can be "restored" annually?
All input would be appreciated!!
T.
Re: Wood And Finish selections for outdoor furniture??
40 years experience, mostly failure
We have two tables that sit under a covered porch, open on the sides to sun and blowing rain and dew. Climate is E.TN.
Table 1 Eastern red cedar finished in spar varnish. It looked great for several years but eventually the mold and oxidation got it to looking dingy and even black in places from mold. The only solution was strip and refinish every few years.
Table 2 White rift oak I thought the table looked sharp after finishing it with Target exterior finish recommended by Target tech guy. He said this stuff was used on boats. In one year it showed black splotches from mold and in two years it was UGLY. Attended a tech session with General Finishes chemist. He showed examples of stuff finished with GF exterior water based varnish. Tried it and after two years the finish was moldy. and faded on the sunny side. Refinishing does not get the black mold stain out of the pores.
Interior window trim on south exposure- Spar varnish disintegrated after a few years. Refinished with $$expensive$$ marine varnish. The stuff is very, very dark amber. I hate the looks of it but it has lasted more than a decade.
Made a maple table for daughter to sit on a covered, screened porch. Finished with Target exterior varnish (the urethane I think). In only a few months it began to suffer mold growth and fading. They moved it inside for a kitchen work table.
If I make another exterior table it will be painted.
PS- Ipe decking on Creeper Bike Trail bridges. Weathered to a grey fairly quickly and looked ok. Now black from mold growth.
mdclor
I used Sikkens Cetol Door and Window on a door that gets the Texas afternoon sun and it still looks new after 2 years. Others have suggested clear paint for a durable exterior finish, but I have no experience with that.
If the wood is finished and refinished every year and on a protected porch, does it need to be a water resistant species?
Jerry Roberts
I used urethane on a rocker I refinished a couple yrs ago. Its on a protected porch and NO sun.. Held up well but will not work at all in sun. Found that out .
Thanks. And yes, despite being on a covered porch, I am told that rain splash will reach the table.
Re: Wood And Finish selections for outdoor furnitu *LINK*
Grant in Iowa
Tommy,
I have a white oak front door that I initially used Minwax spar urethane on but that didn't hold up well at all, requiring annual sanding and recoating. I did remove the door last summer and installed a temporary door while I completely refinished it with 6 coats of Epiphanes (product came recommended by boat builders I know, as well as scored very well in reviews). It is holding up well, though the prescribed 6 coat coating is rather thick and plastic looking. Since this is a door, which is sheltered by a 6' overhang, and it still weathers, though not so far with the new finish, I would therefore recommend against any horizontal outdoor surface getting a film finish, unless the customer fully understands the issues.
The only recommendation I have for an outdoor "in the wood" finish is Penofin Marine Oil Finish, and I have only used it on decks and railings. They have other products that I would also not hesitate to use. Great products, see link below. no affilliation, yada yada.
I think some of them are banned in California, and they have a nasty habit of spontaneous combustion if stored or used improperly. Not sure about food safety, either, though "rosewood oil" sounds like it might be OK.
FWIW,
Grant in Iowa
Penofin
Sgian Dubh
Every time we make outdoor furniture or artefacts we use the one and only finish that lasts as long as the wood lasts, i.e., a single application of naked (or nothing if you prefer).
I've never met a client that will properly go through the routine of refinishing every year, or every couple of years at most. They always skimp, even if they do declare they'll do it, unless they have servants that do the job for them. Best choice in my opinion is a durable wood, e.g., white oak, teak, etc, and just let it age to a grey. If it gets a bit scabby and black, it can be scrubbed off once in a while with water and detergent, along with some fungicide if wanted.
And I've never found a finish that will last without regular maintenance. Boat owners seem to spend more time re-doing all the bright work than they ever do sailing the blasted thing, ha, ha. Slainte.
Gary Smyth
Tom,
Are they buying a table or buying your design sense? What level of sophistication are they looking for? My gut is that they are taking your craftsmanship as the given. They know that whatever is built will be done well, far beyond what is typically available by most other sources. Is it possible that what they want is just a table--something they have seen in a picture somewhere? I guess I'm asking you to ask them is what they are looking for fine furniture or utilitarian. Can they possibly expect a heirloom table with minor change on a yearly schedule for outdoors in weather? That is a no win situation.
I know that it is very soft, but would redwood serve? Teak? When serving food chances are there will be a cover of some sort anyway. Color and weathering of any natural wood outdoors has to have crossed their collective minds. Refinishing a table for twelve will be a task in excess of what most people will indulge on an annual schedule.
Give them facts and alternatives with wood trade offs and perhaps they will make a decision easier for both them and you.
Maintenance required
Tom, good ol spar varnish will work if you put at least three coats on to begin and religiously apply another coat every year thereafter. I did several experiments when we were making driveway gates (mahogany, teak) back in the 80s and90s, and never found a single clear coating that lasts more than one year when exposed to sun. (Actually, Cetol was not included in that test, but I've heard accounts that it will go two years. The reason I never considered it is because it is not transparent enough for my tastes.) The only thing that will hold up for a longer time without routine maintenance is pigmented paint.
PS See if you can find some amargo-amargo (from Central America). I doubt you will, but it looks like a reddish version of wenge, is half the weight of ipe and lasts forever outdoors. I would definitely not use maple or other non durable wood, nor redwood or western cedar (too soft). Cypress lasts, but it flakes nastily at the grain lines in flat sawn material and it's pretty soft. Black walnut is surprisingly durable outdoors and might be an alternative for you.
refinishing
Outdoor designs typically have places for drainage (slats for example) which leads to places near impossible to easily refinish.
Tony - Memphis
I built a garden bench out of teak a few years ago. It resides on a covered porch. It get some direct sun in the winter months and does get some rain when we have a decent storm. I used Teak Oil. I also built a small patio table out of african mahogany ( I think) that I used the teak oil on. They both have held up very well and are not grey at all. Actually, the table is in the shop now with a fresh coat. I just sand clean it up, sand lightly, and apply a fresh coat. Both have retained their natural color over several years. There have been a few stains that I have had to work on (not sure what happened - not from spills), but other than that.... There are several types of teak sold out there and I don't recall what I bought. It is extremely expensive, but I caught a good sale. The wood is beautiful IMHO. The oil brings out a real nice golden brown. This teak was nice to work with, but it dulled every tool within a 20ft radius - even those that just got close! Whew! It even carved well. I carved volutes on the arms. Wish I could get some more to build another bench for the yard, but we have no lumber stores in this area anymore - bummer. The african mahogany (is that sappele?) is holding up quite well and is very nice too. It is available with figure too (I have some). I haven't looked it up to see about its durability outdoors, but mine is doing well ona covered porch. I added teak pad feet to keep it from soaking up water via the end grain and also from getting torn up. I coated the bench leg bottoms with epoxy. Oh, I used epoxy and Titebond III - no problems so far. Anyway, good luck with the project.
Tony
I'm all for naked too.
Keith Newton
QS or rift white oak, mahogany, sapele, or teak all look good. Richard, when I kept my sailboat in a slip, about twice a year, I would mix half bleach and water in a garden sprayer, to wet it down, then follow with a fresh water rinse. This gets all the mold, mildew and bird poop out of the pores, and only takes a few minutes.
However over the years, both the Sun and bleach erodes the porous rings out, leading to a weathered roughness. But that can easily be eliminated by following this annual cleaning with a random orbital sander with 220 disk. All you are out, is a couple of disk, and you are back to brand new wood.
Also, keep in mind that air dried is the MC you are after here, notKD.
Re: Maintenance required
William Duffield
Why does no one recommend black locust (Robinia pseudoacacia), sometimes hyperbolically called "Appalachian teak"? I don't think it is the barbed wire that's usually stapled to it that makes it last 25 years in a post hole.
Grant in Iowa
Tommy,
Williams Black locust comment reminded me that I had seen a black locust table online somewhere, so I hunted it down. Find the link below to Right Angle Woodworks.
He mentions using "PPG architectural sealant to prolong its natural beauty against the elements".
The guy is even fairly near your neck of the woods. Maybe you could look him up.
FWIW,
Grant in Iowa
Right angle woodworks
easy answer
In all the years I have hung around saw mills I have only ever seen about 100 bd ft of it sawed. At least here in TN the trunks of trees are often deeply furrowed, and the trees don't typically grow with competition to limb out early. As a result the lumber would typically be low grade.
That said I have about 50 bd ft that I would be delighted to sell.
Appalachian teak? never heard the term
Paulsv
I refinished the mahogany on my boat 6 years ago, haven't touched it since, and it looks the same as the day I finished it. And my boat sits outside all summer.
But it's a lot of work, and it's expensive. Start with three or four coats of West System 105 Epoxy, mixed with Number 207 special clear coat hardener. You can thin that about 10%, if I recall correctly- check the label information. Thin coats are best and be careful of runs, because this stuff is hard to sand. Runs can be scraped off with a sharp chisel or cabinet scraper. Sand the epoxy until it is as smooth and flat as you need it. (That's the hard part.) If you sand too much epoxy off, you'll have to add a coat or two.
Then, because epoxy does not have a UV inhibitor in it, finish up with at least three coats of a good spar varnish. I use Epiphanes, and consider it to be head and shoulders above all other varnishes I've tried. Scuff sand between coats of varnish. I use clear for all but the last coat or two, and then matte or their "rubbed effect" for a softer sheen in the finish. Here's a link to the Resin / Hardener:
http://www.westsystem.com/ss/epoxy-resins-and-hardeners
Here's a link to Epiphanes:
http://www.epifanes.com/products.html
To restore the finish, just scuff sand the varnish, and apply more varnish.
Paulsv
Oh, I forgot to add that you can also thin the epoxy by warming it, which makes it easier to apply in an even coat.
Howard Acheson
Not surprising. Urethane is attacked by the UV in sunlight. It will rapidly become yellow, then cloudy then begin to crack and peel. Avoid all polyurethane finishes on exterior surfaces.
I've seen Epifanes recommended here already and that is what I would use.
Jesper, Denmark
Jesper, Denmark
Tommy, my suggestion would be black locust and marine spar varnish.
The color may be a nasty green to start, but it will mellow to a nice brown with a lot of figure. You may have to accept that there may be some insect channels that you only discover when planing.
Seven coats of the varnish are required to start, the first two thinned with mineral spirits or the like.
Two more coats annually are OK for marine use, so every other year should be OK on a porch.
Howard Acheson
I've seen Epifanes recommended here already and that is what I would use. There are other true marine finishes but Epifanes is the best.
Thanks Folks!
I have sent the client a list of issues to consider about an outdoor table. I'd rather lose the job than take the job under unrealistic expectations and disappointment down the road.
T.
Honey Locust
Basil
Lasts like black locust. Nice looking color and grain like black locust.
I used an outdoor wood preserver on white oak and eastern red cedar siding by BUHR BHUR(sp) 20 years ago that had a UV screen in it. It held up quite well in full sun for several years.
Almost 20 years later and some of it still looks ok under the roof overhang.
Maybe it was BEHR
Basil
Can't remember exactly how it was spelled but that's close enough for horse shoes. It was an excellent product and did what it said and held fast for 6 or 7 years with no problem.
Read the fine print on the side of the can and look for a UV screen.
Re: easy answer
William Duffield
I can certainly understand the issues with well furrowed trunks. Like any timber, low branches depends on how closely you plant them (or they seed themselves) and how you take care of them.
I only heard the term "Appalachian teak" once, and that was very recently, but I don't remember who said it. I mentioned it because I thought it was funny.
Urethane and outdoor stability
The name "urethane" describes at least how some of the film forming polymer is hooked together . The name provides no clue as to what is hooked together. Aromatic urethanes, a common interior formulation, will be challenged by UV light. It is certainly possible to imagine something formulated with urethane chemistry that would do as well as anything outdoors. Given that paint companies provide little information on what is in the can we can not make an informed decision on what will work for this application, or that, and we must rely on their recommendation.
