Re: LV Vertical cove panel raising bits
TomD
"I have heard that the vertical panel raisers don't work well. Maybe it depends on the profile. I could see that with an ogee profile the tip of the bit would be spinning at a low feet per second rotational velocity and maybe not give as good a finish as the horizontal cutter which must be traveling many times faster. "
Bingo, and the part it won't be cutting as nicely is the endgrain.
Just begs for a hand plane, even if you don't want to put in the physical effort, it would be worth it for the finish.
A great way to get a simple cove profile is with the table saw. A standard blade will produce the full range, of the width and height of the blade, and all the intermediary steps. This is a well known technique, but it is good enough that Franz Klausz son did his doctoral, or something thesis on it.
It helps if you can think a little in 3 d. I was at the farm with nothing in the way of tools, and I had to produce an elliptical slot in some foam, to act as a crash block for the daggerboard of my trimaran. Basically the boat has an airplane wing stick 4 feet into the water and if it hooks up with the bottom at speed, you want to cushion the impact.
So I eyeballed the profile on the leading edge of the wing. Decided to make the cut X deep into the foam block that the board/wing would fit into. At X depth the wing was Y width. So to get that ellipse, you raise the blade to X height. You then eyeball what angle of skew you shoot the board through at that the blade will have Y width of cut. There is a simple jig with parallel lams of
So imagine a 10 inch blade could be raised to 5 inch height. From the front it would take a 1/8" kerf, but from 90 degrees to the side it would cut a semi circle 10 inches in diameter. All the angles in-between will cut elipses that are 5 inches tall and varying root widths. That is a visualization exercise, to cut panels you would raise the blade, say, 1/2" and skew your work to it. Place an auxiliary fence at whatever angle, on your side of the blade, and pass the work through against the fence from the usual side.
I hit the perfect combo on my foam, and got a beautiful elipse that perfectly fit the board. It was a very hard foam, but it was still very nice to experiment with for this kind of wacky deal. kick-back on a foam board is not something I greatly fear. Not that this set-up is going to kick back if you do it correctly.
http://books.google.ca/books?id=jLHKFzIIYYEC&pg=PA91&lpg=PA91&dq=cutting+coves+on+the+table+saw,+klausz&source=bl&ots=Ou6q-eyk8Q&sig=u_sMHbCly664gMerkdMPh-9m7As&hl=en&sa=X&ei=oRSrU9TJNcefyATV-4K4BQ&ved=0CCEQ6AEwAQ#v=onepage&q=cutting%20coves%20on%20the%20table%20saw%2C%20klausz&f=false
