Need a longer miter slot bar
Henry Higginbotham
I'm making a sled for my band saw and need a longer miter bar--one of the adjustable ones that eliminate slop.
I have an Incra bar that's about 25" long, and would work adequately if it had at least one more set of adjustable discs, and if the end discs were closer to the ends of the bar. That would give me considerably more wobble-free travel for the sled (the band saw table is only about 17-18" wide),
So I'm looking for either a longer bar, or one with more adjusters, or both. Internet searches have so far yielded nothing really useful. Anyone know of such a critter?
Re: Need a longer miter slot bar
I make my sled sliders out of 1/2" HDPE sheet (supplier > U.S.Plastics.com) that I then slice to 3/4" on the saw and shave (abrasive or jointer) to just fit with no slop at all. Attach with 2 screws from above and . . .done.
William Duffield
To substantially increase the precision of your cuts, you will need to increase the length (and precision) of your miter slot as well as your bar. Incra also makes longer metal miter slot bars which you can mount into an auxiliary table.
Not To Be Contrary
But I don't like the "adjustable" bars because they rub one side of the slot or the other at only 2 or 3 points. The HDPE bars make full contact with the entire length of the slot and slide easily on the metal surface so long as the slot's faces are not burred.
Why HDPE won't work
Henry Higginbotham
I've used HDPE, too, on a few jigs. It does work very well and can be fine tuned with a block plane.
But in this case the sled is a 12- x 28-inch piece of 3/8" steel plate with a grid of 1/4-20 holes for stops, chocks, hold-downs, etc. and a replaceable wood strip along the blade side. The blade is around 7" from the infeed side of the table. So if I wanted to load something the full length of the sled, I'd need the bar to extend forward enough to make the sled fully stable at the start of the cut. HDPE of course bends too easily.
If I had my own machine shop and could carefully fit a steel bar in the same manner as the HDPE, that would be great. But I couldn't afford to have a local shop do the work right now, even if I could find one with the patience to understand what I wanted.
So . . . I'm looking for a longer version of the Incra steel bar, to give me a longer effective stroke with the jig. Extending the table slot would do the same thing so I've not ruled out making an overlay top with an embedded 36" T-track, but it's not my first choice.
Sounds Like
the real solution is a sliding table rig.
You could also use the left side of your saw table as an indexing surface which would give you two guiding surfaces. The outboard guide could simply be made with a length of angle iron faced with HDPE that extends beyond the leading edge of your sled. You'd have to have the outboard side of your saw table dead nuts parallel with the left-hand miter slot to prevent it from binding.
Over fretting the fit in my opinion
When I needed a longer bar I got a piece of steel bar stock the right nominal size and it has done fine. I have never experienced a problem from the small amount of play.
I would make one...
John in NM
But then I do that kind of thing.
I've drilled and tapped for nylon set screws to take up sideways slop. Easy to do, even without a machine shop. I would do that instead of those little disks. Put in as many as you like, one side or both, even on the bottom too if you like drilling and tapping.
Cold draw steel bar is usually a few thousands under size, so you could buy a 3/8x3/4 bar from McMaster-Carr or another outfit that sells by the foot rather than 20' sticks. A couple feet would likely run $10-$15 + shipping, depending on where you get it.
Dick Coers
Sorry, no answer to your questions, but your fixture description reminds me of the old Timbermaster attachment that Laguna used to offer. Can't find a link, but saw a picture in a Google Image search. It had two steel cabinets, one on each side of the bandsaw, with a precision steel bar between them. The sled moved on the table of the bandsaw and linear bearings riding on the bar. Handled a ton of weight and was very accurate.
Henry Higginbotham
That's more help than you think! True, it doesn't address today's project, but for a few months (or more) I've been accumulating part and ideas for a poor man's version of a mini-lumber mill for my MM16. Rather than custom castings and full roller transport, mine is likely to consist of what I have or can find for cheap. V-groove iron casters and a 10-foot stick of Unistrut are expected to be the guidance method and should allow me to cut lumber about five feet long. The quality of cut doesn't have to be as precise for rough lumber as what I'm looking for in the smaller sled.
I found a video on YouTube of the Laguna Timbermaster and may borrow an idea or two for mine.
Full length miter bar shimming
Lee Schierer in McKean, PA
On my Craftsman TS, the factory miter bar was loose in the miter slot. I purchased some UHMW tape in .005 and .007 thickness and added a strip of tape along one side of my miter bar. It adheres well to the steel and slides nicely in the slot. I eliminated the slop. UHMW tape is available in .005, .007, .012, .022 and .036 inch thicknesses from McMaster Carr.
When the tape gets nicked up or damaged, it is easy to peel off and add a new strip. I trim it flush with the top and bottom of the bar with a sharp knife or razor blade.
Lee
William Duffield
Another woodworking appliance along the same lines, which might give you some more ideas, is the Jessem Mast-R-Slide. Last time I looked they were about $600 apiece, and they're for a table saw, not a bandsaw, so you won't want to go out and buy one. You can look at the user's manual here:
http://www.jessem.com/PRODUCT_MANUALS/Mast-R-Slide_7500_Manualcx.pdf
A Google image search will find lots more photos of it.
Re: Why HDPE won't work
William Duffield
There's another relatively low tech way to make use of the HDPE. Make a composite slider, with a core of steel or aluminum bar and an HDPE bar attached to each side with countersunk machine bolts. If you can't manage to build one that's both slippery enough and stiff enough in a 3/4" x 3/8" space, that's not a problem either. If you are building an auxiliary table, you can make a custom miter slot any width and thickness you want. Aluminum bar stock is remarkably straight and easy to drill and tap, and you can still fine tune the HDPE with a shoulder plane.
examples?
Does anyone have data that says a zero clearance miter slot-bar combination is necessary? No doubt it is desirable if trivial to achieve, but a composite bar to get to this goal?!?
My Unisaw has a home made extended bar made from 3/8 x 3/4" bar stock and it has seen 40 years of use building furniture. It never was, and certainly isn't now, zero clearance. What ever wiggle might be involved is easily compensate for by just shoving the miter assembly to the right in use, if indeed even this operation is necessary.
I see lots of ancient Delta and their Powermatic equivalent saws in professional furniture making shops and these slot/bar combinations have worn to be even looser than when purchased. Yet this situation does not appear to be a practical limitation.
Before I spent much effort obtaining a zero clearance bar-miter combination I would want to determine how much clearance resulted in a practical effect.
Re: examples?
William Duffield
Those are all excellent points, Bill, and they agree with my experience. I was just suggesting strategies that might work, given the restraints that Henry described.
Perhaps it would help if we knew what he is building, and what tolerances he requires in his parts. If he's building wooden puzzles, or segmented turnings, he might need more precision than we need for most furniture forms. Another question might be why he needs to use a bandsaw instead of a cabinet saw (or even a vintage radial arm saw).
Practical example
After aligning my saw blade to the slot to get burn free and toothmark free cuts, I tightened up the bar on my saw when I noticed occassional burn marks on cross cuts and found that it was due to me shifting the miter gauge within the slot during a cut. It makes considerable difference when cutting tenons with a tenon cutter as the amount of slop can easily double from one tenon to the next making fits either too tight or loose. I probably could have avoided problems with better technique, but taking the slop out allowed a faster and permanent cure.
It can have some effect on miters when cutting picture frames, which becomes apparent on long sides. I can't give specific values, but every little bit adds up.
Attempting to align the blade to the miter gauge slot and fence with a sloppy miter gauge can be a source of frustration.
Lee
Why not hammer the bar???
I like the idea of the tape, but I thought the classic way of fixing this was to hammer or peen the bar, making slightly wider at several points and then filling it to the exact fit.
Why it matters to me
Henry Higginbotham
I've used the always-push-it-to-one-side method with jigs on the table saw and it's always worked adequately well. The workpiece being cut on a table saw usually tends toward low and wide and thus not inclined to move much on the jig or sled.
But we're talking about band saws here. This idea that I needed a sled came about when I wanted to cut off an end of an octagonal column at a 5-1/2° angle. The cut would have been 9" high. There starts to be more to worry about as you're making a higher cut, and miter slot slop looked like something I could eradicate once and be done with it, free to concentrate on the other 28 things that could go wrong during the cut.
Here's the problem
When you peen or center punch the bar, you are raising small areas of metal that make the bar a bit wider at those points. As you use the miter gauge, those raised areas wear off and you are back to square one with a sloppy bar. If you are over aggressive you can actually make the bar too wide so it binds and you end up filing it.
With the tape, if you damage the tape, you simply peel it off and put on a new strip and you are back to tight in a few minutes without having to measure and check. Typically I find that the tape lasts several years and that the low friction of UHMW allows the bar to slide smoothly.
Lee
sled runners
I made a sled for table saw and used a hard white oak with growth rings oriented for minimal dimension change across the width. I made it snug and at least given the humidity changes I experience in the shop it stays snug without binding. I do wax it. Unless you intend to use the sled greatly more frequently than I the oak will last a lifetime or at least half.
