Drawer fitting
Drawer fitting
Drawer fitting
It is not easy to build a case and drawer and have the two fit perfect without adjustment. Hence, fitting a drawer to a case after the drawer is built is a routine furniture building practice, easily accomplished with a hand plane. I target the drawer to be too tight when it is made and then remove width and height to get the perfect fit.
It seems a fashion in the popular press to strive for tight fitting drawers, which they use a silly name for, that I will not repeat so as to not further popularize this flawed concept.
The goal is simple. The drawer must not bind, nor rack excessively when it is closed.
Racking: If a drawer has too much clearance on the sides it will rack as it is closed, and bind. From the study of antique furniture I have concluded that something on the order of 1/32 side clearance is about right to enable smooth closing. Waxing the sides of the drawer and cabinet makes the operation even smoother.
Drawers do not change in length with humidity change. If the drawer is fit to length once it will stay that way, presuming the case sides don't warp.
Height clearance: Drawers do change in height in response to humidity changes. The target is to have a bit of height clearance under the highest humidity conditions the drawer will ever see. When the drawer height shrinks at lower humidity the increased height gap will have no adverse effect on the drawer operation. Hence, it makes no sense to strive for a too tight height fit. An 8" drawer built in the dry winter months may need 1/16" of height clearance to function well in a humid location.
Re: Drawer fitting
Re: Drawer fitting
Paul in NJ
quote:
"Drawers do not change in length with humidity change. If the drawer is fit to length once it will stay that way, presuming the case sides don't warp".
While drawers won't change in length, if your case is made from solid sides (not frame and panel), the depth of the case will change with the humidity. The solution is to make your drawer a little shorter and put drawer stops at the front of the case. Just a simple block glued to the drawer blade (divider). It makes contact with the back of the drawer front at the bottom (I hope that makes sense).
Paul Dzioba
Re: Drawer fitting
Re: Drawer fitting
Alex Y
I had the same reaction. But I think from the comments he made that when Bill referred to drawer length, he might have been referring to the length of the drawer front (i.e, the drawer width).
Just a guess.
Re: Drawer fitting
You made sense....I didn't
I should have said width not length.
