Novel extending table *LINK*
Dick Coers
We had the discussion about the butterfly leaf table, here's a fancier one!
wrap extending table
Dick Coers
Re: Novel extending table
Mark Meier (Ann Arbor, MI)
Thanks for the link. That's actually pretty neat. And it appears simple. I'd love to see a section through it to see exactly how it operates.
I see they want over $10K for it. Fantastic if they can get it.
Mark
Re: Novel extending table *LINK*
mdclor
Mark, the mechanism appears to be very similar to a Dutch pull out table as illustrated by Tage Frid in FWW #7. If you look at that, I bet you would be able to figure out the mechanism for this table. Personally, I think $11K is pretty outrageous.
http://www.finewoodworking.com/woodworking-plans/article/designing-for-dining.aspx
William Duffield
If you can't get ahold of the FWW premium content, I think I still have the top and leaves of one of those tables out in my shop. Not specifically the FWW plans, but the same thing, built by Levitz back in the '70s. I could probably get you pictures and measurements. The legs and aprons are still around somewhere, too.
Yes, actually I was not able to see the premium content.
If you have a chance to take a few pictures that'd be great.
Thanks!
Mark
mdclor
Mark, maybe this pic will help. The table top floats on the center piece. Two short dowel sections keep the top aligned with the table. The two leaves are attached to slides set at an angle. As the leaves are pulled out they are forced upward due to the angle. Is is necessary to put felt on the underside of the top to avoid marring the leaves as they are pulled out. You need to lift the top the thickness of the leaves to slide the leaves back in. Email me directly if you have more questions because I know I have not explained this at all well. Unfortunately, I don't have the one I made to take any pix.
Ahh... I see exactly what you. That picture and your explanation were very helpful.
Thanks,
Mark
William Duffield
First, while perusing the Google Images whose link MD provided, I found another set of FWW plans that are not behind their firewall.
http://www.finewoodworking.com/item/23883/monticellos-universal-table
I found the top and leaves of mine in the barn. If you can ignore the spider poop, spider webs and sawdust, these photos should be educational. I don't have access to the base right now. Coincidentally, it is in Lake Monticello, just a few miles from Jefferson's Monticello. That's not a problem, since it is simple: four legs, four aprons, notches in the end aprons to clear the rails attached to the leaves, and a stretcher spanning the tops of the two side aprons.
The top and the leaves are not attached to the base. They float and are held in place by gravity.
All the photos show the mechanism upside down, looking at the bottom surfaces of the top and leaves.
This shows the top with both leaves in the closed position. The two inside rails are attached to the left leaf. The two outside rails are attached to the right leaf.
Here is the top, with the leaves removed. It shows four black plastic cams that ride in excavations in the rails. It also shows two buoy shaped wooden alignment pins that engage holes in the stretcher, with a loose fit. These hold the top in position as it moves up and down as the leaves are pulled out and pushed in.
Cams and pins, side view.
Cams, end view. Note that the cams are offset. The closer cam engages the inside rail. The further cam engages the outside rail.
To more clearly show the mechanism and operation, the remainder of the pictures will show only one leaf at a time.
Here, the left leaf is closed, completely under the top.
Here, the left leaf is half open.
Here, the left leaf is almost open, and the top is almost ready to drop between the leaves.
Here, the left leaf is all the way open.
Here is the right leaf, closed, showing the excavation on the inside of the far rail.
The dowels in the bottoms of the rails engage the sides of the unshown stretcher, to keep the leaves from sliding in too far.
William, thanks so much for much for the clear pictures and description! I appreciate it.
Mark
