Toggle clamp parts source?
I really don't need the whole clamp - but I do need longer bolts with the rubber tips. Unless y'all think I can just go to Home Despot and buy longer bolts and put rubber tips on them.
The problem is that when I made the jig, I really made one piece too thick. I would hate to have to remake the piece - though I will if that is my only choice.
If the clamps are available with longer bolts - I will take those also.
I need the type of clamp where it holds down the work piece.
Re: Toggle clamp parts source?
Google De Sta Co. The Essentra mentioned above came up.
Gary Smyth
If you have a Harbor Freight nearby check out what they offer. Not expensive. Online specify "clamps" and what they have will show. What I have is a bit smaller than the De Sta Cos. Most of these type clamps are a simple bolt with a a couple of nuts that enable adjustment for length.. Pick a bolt of the same diameter, but longer, and screw it in then cap with the nut. That is one alternative that might work depending on your jig. If that doesn't work you can "lengthen" the bolt of what you have by adding a block of appropriate thickness wood where the pad is. You can drill a hole in the wood to fit the head of a bolt and add vinyl/rubber shelf liner on the bottom of the wood and it should hold -- perhaps better than the cheap pad that gets crushed with each use. If all else fails and all you need is a pad, call the manufacturer. If not free then, I bet, cheap. Problem is, unless they comp you the item the shipping will be more than the item itself.
Keith Newton
I'll bet you could use a carriage bolt, with a rubber walking stick tip, bonded with mastic or silicone.
Thanks
This looks to be the ticket.
I can even order more clamps.
