Spalding Wood
Spalding Wood
Spalding Wood
Ken Hager
Help!!!!! I just purchased a 700lb buckeye burl. would it spald faster if I cut it up in several pieces or just keep it in the dark and keep it damp?
Re: Spalding Wood
Re: Spalding Wood
A. The term is "spalt" no "d"
B. Most importantly, spalting is the result of several fungi coupled with the right conditions. If the fungi spores aren't in your piece already, you will be wasting your time. You can, however, inoculate your piece with the fungi spores which you will find aplenty in the woods were you see sh'room fruiting bodies on logs and trunks. Look for the small black caps growing in down wood and the white ones "blooming" on the cut ends. Harvest the spores from the heads, mix them in water, then inject the mix into your log at various intervals. Keep the wood wet and warm. You can accelerate the process by getting some 46-0-0 fertilizer, (urea) dissolve it in water and keep soaking your log with it.
Good luck.
PS: Beer (new) won't help ("used" beer may) nor will any number of crack-brained home remedies from yogurt to cat poo that you'll find floating on the Net.
Re: Spalding Wood
Re: Spalding Wood
Craig Daymon
There was an article a while back in an issue of American Woodturner. Don't know if you are planning on turning this or using it for a flat project. If you don't have a membership, you may still be able to purchase the back issue. Might just cost a couple dollars more. The article mentions some types of fungus and the resulting color/type of spalting produced.
Rember that spalting is part of the rotting process and that your rather large burl could easily turn to 700lb of mush, so be careful. (Though, not likely the whole thing will go at once.) The other issue may be that the spalting will only penetrate so deep. It is not a given that it will alter the entire burl.
Re: Spalding Wood
Her Name *LINK*
is Sara Robinson. Her article appears in American Woodturner (AAW Journal) in December of 2010. She also has a book out which gives detailed information and directions. You can also get a lot of info free from her website at the link
Spalting
Re: Spalding Wood
Hey Mark, Have you tried this?
Keith Newton
You mentioned keeping it wet, which is important, but not too wet. There is a range that decay can grow in, and being too wet is as bad as being too dry.
It seems to me that I am seeing lots of just rotten wood labeled as spalted, whether it has much of the black zone lines in it or not. To me, that is the only part I find attractive, anything else is just degrade.
Having a nice burl, with good figure, then wanting to risk messing it up to make it beyond where it is, is somewhat like guilding the lilly.
Re: Spalding Wood
Actually
yeah, but it took a while and I'm much more prone to just go with what I get when I first open the wood, especially since I don't have the space to have logs sitting around in water trays or the goal of various types of fungal spores floating around in my basement shop to get circulated through the house. Sara approaches the effort as a kind of artform, using different fungi for different colorations. I'm just not THAT into it. ;)
Re: Spalding Wood
Re: Actually *LINK*
Craig Daymon
I've seen some very impressive work done by using multiple analine dyes (TransTint), sanding back between colors, to generate some spectacular colorization on burls. Might be the safer approach, possibly a bit more colorfast than coloring from spalting.
Don't know of a good article on the subject, but I suspect there is one out there somewhere. Maybe try Woodturning Online. They have a good size collection of articles, or links to, on their site covering a wide range of subjects related to turning. They do have a section dedicated to spalting in their articles list. Coloring with dyes might be there somewhere, but I didn't see an obvious category.
Woodturning Online
Re: Spalding Wood
Go To
Dr. Robinson's web site in the prior link. The lady "wrote the book" on spalting wood for fun and profit.
Re: Spalding Wood
Re: Spalding Wood
TomD
I just throw it in a garbage bag, and let nature take it's course.
