OT - Water leaking from battery
Stephen Kirk
We just topped off a small lawn mower battery with distiller water prior to charging. We let it charge for several hours on the 12 volt 2 amp setting with no noticeable effect. So I thought it might need the 12 volt 6 amp charge setting. A short while after that the battery started to show charge, but then water leaked out of the fill caps.
Question - is water leaking from th fill caps dangerous - ie contains sulfuric acid? I put on some latex gloves prior to wiping it up, just in case. But I want to make sure the table it was sitting on doesn't need to be more thoroughly cleaned as well. The battery is sitting outside, not on charge anymore.
I'm thinking it maybe got too much water then the higher charge boiled it, but I'm not much of an expert on thes things. Plus the batteries don't actually have printed on them what they are, like 6 or 12 volt - that seems odd.
