A Custom-made Brass Door Pull
Alan Young
Alan Young
I am working on a Sheet Music Cabinet. This piece is a commission from a friend from college days. He already commissioned two earlier music cabinets for graduation gifts for two daughters. This third cabinet is for his last daughter's college graduation.
I made a Brass Pull in the form of a combination G and F Clef. Here are pictures of the process. I made this pull by first drawing the design, then fixing it to a piece of brass with double sided tape. The brass is then clamped in a milling machine vise.
I milled a 1/2 diameter recess with an end mill.
I replaced the 1/2" end mill with a counter sink and drilled a hole for an 8-32 screw that will fix the Double Cleff Pull to the rest of the piece.
I replaced the counter sink with a smaller end mill and mill out the interior sections of the profile.
Once the interior lines are milled out, I take the work piece to the band saw and cut away the rest of the profile.
From this point onward it's all file-file file!
Now to the lathe where three different sized hex pieces are drilled and turned for the remaining sections of the mounting hardware.
One end of the 1/2" hex is tapped for the 8-32 screw. The other end is tapped for a 1/4-20 screw.
The 1/4-20 goes through two 1-1/8th hex pieces and one 3/4" hex piece. The door section will be between the two larger pieces.
Here is the cabinet as work-in-progress....
Re: A Custom-made Brass Door Pull
question
Band saw picture- there is a slotted piece of metal to left. Is it part of the sawing process?
The word elegant came to mind upon seeing the cabinet. Love the design.
Alan Young
The Slotted Piece--
Alan Young
Yes Bill-I was using the aluminium piece ( from a project at work)with my left hand to guide the cuts-notice the jaws of the vise grip holding the other end--I would have a difficult time pulling off this piece without access to the machine shop.....
Glad you like the design-a bit of refining still to go on it but it must be ready in a week as I am taking it with me for delivery.
-Alan
Wow!
Tony - Memphis
That is really nice!
Tony
Re: 2nd that - Wow !
Unique!
...and very imaginative. Getting beyond wood as the only medium. Love it.
Great work, Alan!
Keith Newton
Alan, was that your only choice for bandsaw blades? It looks to me that you should have been able to cut a lot closer to the line than that. I think I would have been able to cut just outside those long sweeps, with my wood-cutting blades, with a whole lot less filing.
One thing I do when cutting metal like this, is to put a scrap of 3/4 mdf or plywood, which I cut out into the middle of, leaving it there as a zero clearance raised bed. This takes care of any chatter possibilities around the opening toward those thin ends, plus gives my hands a better grip, where it overhangs that sub-base. But you probably like filing more than I do. ha
Oh by the way, where did you get the metal, and how much does it cost per sq. ft.? I was over at my local salvage yard yesterday, and spotted 4 pieces of 1/2" x 6" X 12". I should have picked them up, but had already settled up with them. I have a project in mind where I would make a pair of fluted elliptical columns which could open up to reveal drink bar bottles and glasses etc. inside.
Alan Young
Alan Young
no...I could have replaced it with a narrower blade ..didn't seem to be an issue at the time..
Good idea---not much MDF available in this shop
There is an Alro store here.(Ann Arbor) I cut this from a piece of brass-1/4" x 1 1/4" x 12". That piece plus an 18" long 1/2 hex bar ran me $25.00....
