I have a potential client who wants a custom dining table built. For the top, they want the table to pull apart and have leaves that pop up in the middle, from down below. Then you push the table back together in the longer form.
Is there a hardware kit that works well for doing that? If so, could anyone send me a link or give me any advice? Thank you!!
I have such a table that is without special hardware, just various wooden slides and notches. I didn't make it, my parents originally bought it in 1981 when we arrived in Taiwan. My (now ex-)BIL copied the functionality of it to make a dining room table for my sister's family several years ago, and when that project was finished, we then inherited the table. I have not closely investigated the mechanism, though. If I think about it tonight, I could send you pics/video of its operation via email, if you're interested.
Not sure you can buy the hardware. A couple of projects shown on the web just show a pivot rod and wood stops. Well, that and some table extension slides.
Tage Frid described a table similar to this description in his trilogy, Tage Frid Teaches WOodworking, vol. 3, if I remember correctly. He called it a Dutch pullout table.
This has also been described as a project in Woodsmith.
I have built a dining table based on the description by Frid as a gift for my daughter several years ago. It uses no special hardware, and the action is very simple. Works using tapered runners on the leaves and a top not attached to the frame. The table still performs well with o problems.
A butterfly leaf table - never, until now, knew the name - was our first dining room table in our house, 40 years ago, and until we cleared out my parents' house several years ago. It had a simpler pivot than shown in the link Dick Coers offers - basically just blocks in which the pivots are installed - but works the same way. Our uses regular table pins to register the leaf to the sliding leaves.
It works quite well, although it requires a fairly sturdy apron, as the leaves themselves provide no structural strength at all. And you're limited in your expansion to whatever decision you make about the width of the leaf. You don't get to add more leaves when more cousins show up for Thanksgiving. Within these constraints, though, it's a great design, because the leaf is right there, easy to find, no need to make closet space for storage.
Do use stable wood, though; I can imagine what it would be like trying to get that to work if any of the parts warped.
Bill, the most common name I've come across for this type of table is a 'flip-up and over extending table' and the method of construction is detailed in Ernest Joyce's The Technique (Dictionary in the US I believe) of Furniture Making. I've never before heard of the mechanism being called a Dutch Pull-out, and calling it a butterfly mechanism is a fairly logical choice. It's interesting to me that the same mechanism has a few names, but that's nothing new in our profession, especially when you look at traditions in different continents and countries, e.g., dado/housing, etc. Slainte.
Tage Frid describes a Dutch pullout as having extensions, one on each end, that slide under the main tabletop. They are pulled out on slides when needed. I've never seen one in real life; only in his books. They are, indeed, a very different design from the one I described in our original dining table.
Given that description Bill, I looked it up, and it's what I know as a draw-leaf table. A search using both those descriptions will show they are the same mechanism. Slainte.
Jason, would send the same thing to me? I'm going to make a dining table for my daughter and her husband for their first anniversary (in ten months) and we discussed this same set-up. I saw one in a furniture store 20 years ago. I don't remember any of the details.
