Looong T-bolts and drilling paper - help!
Craig Daymon
I ran into a problem today working on a gift for my niece. I've written a computer program that takes a video, allows you to select a clip from the video and generates a flip book to be printed of the clip.
I printed out the images, stacked them all up and tried to drill through the stack so that I could insert Chicago bolts (or whatever their other name is) to hold the stack together. When I drilled the first hole, the paper climbed the bit and the stack became much thicker in that side due to fraying of each sheet.
I realize I need a better way of clamping the stack before drilling in order to do this correctly. I am using a brad point bit. I have 2 T-tracks in my drillpress table and if I had longer T-bolts, maybe 6"(?), I could drill holes in a strip of wood same distance apart as the T-track and use the wood to clamp the paper in place and, if necessary, drill right through the wood and through the paper.
Anyone know where I can find T-bolts of that length that will fit standard mini T-track? (3/4" wide, 3/8" thick T-track)
Or if anyone knows a better approach to cleanly drilling a stack of paper, I really appreciate some help.
Thanks.
Oh yeah, there are 2 small strips of jatoba involved in this to dress it up a bit, so there is some woodworking.
