Ceiling Fan Remote question....
Sold the house I have been working on. One of the requests was a ceiling fan in four different rooms. So, If I put Identical fans in two smaller bedrooms and two different ones in the Master bedroom and living room, will the remotes talk to each other? If you are in one bedroom and turn the fan on, will the fan in the adjacent bedroom come on?
There are switched receptacles in the rooms so I decided to take the easy way out and put in fans with light kits and remotes.
Re: Ceiling Fan Remote question....
Lee Schierer in McKean, PA
I imagine remotes for fans of the same model would probably talk to any other fan of that model. If the transmitter is a IR type instead of RF type, it will not likely go around corners and will not go through walls. The IR types are pretty much line of sight to the sensor.
Once when visiting friends in Ocean City NJ, I was watching our Television and noted that the house across the street was also watching TV and the TV was facing me. Just for chuckles I pointed my remote at their TV and hit the channel change button. The TV across the street changed channels. I did this several times over course of a half hour. They were going crazy, but I don't think they ever did figure out what was causing the channels to change.
Lee
John Veerkamp
Some of the fan remotes will talk to the same brand but must be educated to the specific device. I just installed one in my daughters house and had to do a couple of easy steps to train it. I don't know if the same remote can be trained to multiple units at the same time or just one at a time.
Jason Roehl in Lafayette, IN
Yes, and maybe no.
The remote and receiver in at least some brands have DIP switches in them that allow you to either key multiple fans to one remote, or allow several fan/remote combos from the same manufacturer in the same structure. At least that was how the two I bought about 6-7 years ago were (the remotes were cosmetically different, but would still operate the other's fan until the DIP switches were uniquely set.
Jason
So today I installed the fans....
Of course I waited for a day when it would be 97 degrees outside with not a cloud in the sky. Got to the house about 7:30 AM. Tried to quickly rough in the wiring from the attic. There were not boxes in the ceiling. Turned out the AC ducts beat me to the punch and were dead center in each room. Hmmm! Could not have been more in the way. I cogitated for a while. Ciphered some. Finally moved the fans about six inches from the ducts Used the fan boxes that straddle the joists. Had two pairs of fans. Similar but different. Its not that the hanging system is poorly thought out, its just that they were designed by some ignorant savage that lives in a mud hut without the benefit of indoor plumbing or wiring. I'm not a violent man, but I would like to find the designer and pimp slap him.
The remotes had DIP Switches and they all come set the same way. Since I had two pairs of fans, I changed one setting in each pair. In my case, I wanted the remotes to be tuned to an individual fan so that they would not take to each other.
Took about an hour and half to get out of the attic and it was already hot. I was soaked. Then spent the next five hours putting up the four fans. It was hot in the house, especially up near the ceiling. Drank five quarts of water. I overwhelmed my deodorant so badly my dog is offended.
One pair of fans came with batteries for the remotes. The other one did not. At lunch I had to make a side trip to get the batteries. I had so much sheetrock dust on my face the woman in the hardware store asked me what was wrong. Told her it was skin condition. She appeared shocked and apologized.
Joe Bradshaw
Re: So today I installed the fans....
Joe Bradshaw
Barry, don't hold back. Let us know how you really feel.
