OT - Question on TV Cable Box Remote
Ralph Lipeles
My Cable box remote uses 2 AA batteries. When the batteries are fresh, the remote turns on the cable box and the TV also turns on. I believe that the cable box turns on the TV. However, when the batteries are a little weak, about 1.45 volts, the remote will still turn on the cable box, but the TV will not turn on. Why is this?
Re: OT - Question on TV Cable Box Remote
del schisler
is the tv plug into the back of the box, must be? is the box belind anything line inside a stand with glass or plastic of any kind, if so remove it so that the inferred sencer can see each other, how far away should do 20 or so feet, look in the book it may say, did this just start ? or when new, if new take it back or replace both unit's , if in warrenty ? get a new universal remote ? just a few question's
Ken Krawford
My remote turns on the TV and cable box. It is a 2 step process. It turns on the cable box first and then sends a signal to the TV. If you press the ALL ON/OFF button and point the remote away from the TV too quick, only the cable box goes ON/OFF. Try pointing the remote directly at the tv's infrared sensor and hold it there for a few seconds when powering ON/OFF and see if that helps.
Ralph Lipeles
The TV plugs into the wall receptacle, not into the box.
Jerry Roberts
I had a similar problem like that a few months ago. It turned out to be the button itself. No matter how hard I pushed nothing happened. Got a new remote and now works fine.
