A55 Smoothing Plane
ipe oil
ipe oil
ipe oil
mcnerney
Does anyone know what kind of oil is used in "ipe oil"
I'm guessing too it must be fairly thinned out
Mike
Re: ipe oil
Clint Searl
Re: ipe oil
Clint Searl
Probably just BLO and solvent. (The same as "teak" oil)
Re: ipe oil
I'd like to find out
I used Cabot's Australian Timber Oil on our ipe porch a couple years ago and learned a few things. First, it is essentially an oil/varnish mix (linseed oil/alkyd varnish) with some pigment stain and 2lb. of VOC per gallon. My hunch is that the "ipe oil" you're referring to is similar. Here's what I suggest: Before you use either of these products (or anything else) on ipe, prepare a few wood samples and experiment a bit with the penetration and film thickness. I found with the Timber Oil that you can't leave this stuff on the wood to dry, because it doesn't dry. You need to thin it, apply it, and then wipe it off, like you would with "Danish Oil" finish. The important thing is to not let it sit on the wood.
I haven't tried this product, though, and maybe it's totally different, so let us know what you find.
