What glue would you use....
to glue plastic laminate (Formica) to a drywall wall? I want to create a wainscot in my kitchen where the rash can sits, for easy clean up. I have used contact cement in the past, but on the last job it did not hold the edges as well as I wanted. In this case the laminate will be trapped behind trim all the way around the edges.
Re: What glue would you use....
John Veerkamp
contact is the right glue. Br sure to size the wall first.
The last may not have held at the edges because the cement on the formica was not as well spread to the edges. BTDT.
Re: ditto...but
C. John Hebert
2 coat's and no need to resize. The second coat is the grabber, while the first get's absorbed.
