Extension Slide Problem
I have to modify the mounting holes in a pair of extension table slides to allow for seasonal movement of the solid oak table top panel. Since the top is made up of panels glued up across the width, I have to modify the screw holes to slots for three of the four holes in each arm to allow the top to expand and contract. So questions:
The pre-drilled screw holes are 1/4" diameter counterbored to 1/2"
1. Do I take the slides apart and use spiral router bits to make the holes into 3/4" slots?
2. Do I chisel the large openings and use a 1/4" side cutter drill in the drill press?
3. ????
tia
Re: Extension Slide Problem
Think what course the screw will take as top expands or contracts. The screw will pivot about the center of the screw hole. So, stick a 1/4" bit in the hole and rock it back and forth. If it needs to, the screw will follow the same track.
I'm not convinced anything needs to be done. Tops were traditionally screwed on with pocket screws that I have not seen to be over bored. In a factory your extension would simply be screwed on and indeed that is all I have done. I think screws must have some magical power to give with the comings and goings of a top.
It would be a good experiment to screw a panel to a rail and see if the screws will hold it enough to split the panel. I'll bet not
Not long after
the table arrived in my shop with the panels screwed to the rails, it started "talking" as the top started to react to the winter dryness. As soon as I took it apart, it went silent.
Keith Newton
I would try drilling a hole beside the other, then use a metal blade in the jigsaw to finish between them.
Maybe a right angle grinder will take care of the countersink area.
William Duffield
I've always mounted table tops the same way Bill recommends. Rock the drill bit perpendicular to the grain direction of the top. If one of the screws is centered on the top, you don't have to enlarge that one. The head of the screw in its counterbore is not going to move relative to the slides, so it has to rock back and forth when the top moves. After you've done that, you might also consider decreasing the friction between the top and the slides. Removing planer scallops, rough surfaces, excess finish, etc., with some sandpaper should also help. Not over-tightening the screws will help as well, and might even help to keep them from stripping out over the years as the slides and top expand and contract. If you're paranoid, you might even put strips of UHMW tape on top of the slides.
My Solution
I've decided to "slot" the screw holes to 1/2" in length with a router bit so that the bottom of the counterbore has a ledge for the washer-head screws to catch. That will allow the ends of the top panels to move through a 1/2" range but the center screw mounting will be fixed to hold registration.
Mark, I'd like to hear how that goes,
Keith Newton
I've never tried routing steel, so would like to hear how it works. I hope you have a variable speed router, and would suggest using the slowest speed, with the widest sharpness angle bit you can find.
Re: Mark, I'd like to hear how that goes,
William Duffield
One of us didn't understand. I assumed the slides were made of wood, and I guess you assumed steel.
If steel, I'd expand them with a chainsaw file, not a router. With thin steel, there's no room for wobble, so leaving a bit of space between the screw head and the slide would be necessary.
If they're wood, the router would work as well as wobbling a drill bit back and forth, and it might be the method I'd use for a large job, when you could recover the setup time after enlarging several holes.
Dudes . .
They're wood slides [but they do have steel gears if that helps :D ]
Set-up is a fence on the router table, a 1/4" spiral-cut bit, a piece of masking tape, and a trap board. Ain't no thang.
Now if they were steel, I'd likely be doing the file thing, but I wouldn't be opposed to getting a bit of time on a bud's Bridgport. THAT can be fun!!
Alan Young
Gimme a call if you're in town
Alan Young
Ooo, Ooo!
I kin smell the cuttin' erl from heyah!!!
:D
