Samantha's Dresser 13- finish on drawers
Stain is 10% burnt umber Japan pigment, 10% linseed oil and 80% neutral General Finishes stain base.
The problem with crotch is that it can go almost black with oil or stain. There are two says to avoid undue darkening- wash coat or dilute stain and oil. In this case I diddled with stain formula until I got a depth I liked.
Finish is Sherwin Williams "water white" conversion varnish. I wanted a close to the wood look. To get it I diluted the finish 50/50 with xylene so that the build would be thin. It turned out the way I intended.
Spray conditions were ideal today and the coating is glass smooth.
