Source - Nuts
Looking for an on-line source for connecting nuts . .
I need 5/16x18 with either a hex or socket drive (pictured). I can get them from Grainger but they want $2 a piece!
TIA
Source - Nuts
TIA
Re: Source - Nuts
John McGaw
Well, Fastenal has them marginally cheaper. Are you sure you don't want to switch to 1/4-20? Those are abundant and cheap.
Re: Change
Can't. These are leg fixings on a piece that is being only partly redone. They are to hold dimensioned legs to the mount board for an extension dining table, and the 2 existing legs use 5/16 hanger bolts (2 each leg) for the primary fixings.
I'll also be doing some re-engineering as the guy who originally made the table appears to have been a plywood carpenter with little or no knowledge of seasonal wood movement. When the table top was delivered, it didn't take long for it to start making noise because the top was expanding and pulling against the screws that held the extension slides and the original mounting board that was (yes . .) a glued-up panel also showing signs of expansion damage. I had to take the whole thing apart to prevent it from splitting.
Re: Source - Nuts
AZ in Colorado Springs
If a connector bolt will work, McFeely's carries them.
Thanx but
McFeeley's doesn't have what I need so after a search on all of my links, I got'em from Grainger anyway.
Re: Source - Nuts *LINK*
Bob Entwisle in NJ
Day late and dollar short but maybe for next time
Bob in NJ
Connector Nuts
Nutz - late but
Next time . . thanks
Craig Daymon
Did you try McMaster or Enco?
I just bought a bunch of "Chicago Bolts"/binding post sets, which are very similar, from McMaster in assorted sizes. I bought them in brass for my project. They have a slot in the screw and the nut is polished smooth.
Lee Valley also sells what you are looking for, though I don't know in what sizes. Look for knock-down fasteners. (They also sell the Chicago Bolts.)
McMaster and Lee Valley only seem to have one diameter and 2 lengths. McMaster is about half the Lee Valley price, but you have to buy 25 at a time.
Here's a link to an assortment of knock-down fasteners from Lee Valley.
http://www.leevalley.com/US/Hardware/Search.aspx?action=n
McMaster-Carr Binding Screws for Furniture
Re: Source - Nuts
William Duffield
The problem with the sources you and Bob provide is that they only carry 1/4-20 thread bolts. Mark needs 5/16-18. I couldn't find any in that size either, at least not at a lower price than the ones Mark already found.
Bob Entwisle in NJ
The source I supplied has the 5/16-18 size that Mark was looking for, but you do have to root around a little for them.
Here is a better link that actually shows the 5/16-18 as well as other sizes.
Bob in NJ
Connector Nuts - 5/16-18+
