So I used the Deck Over stuff.....
I am working on a low end house that has a sort of country style front porch. About thirty years old and made of 1 x 6 treated wood that had been stained/painted dark red. Had 4 x 4 columns and 2 x 4 treated wood rails. Lots of wear and warping.
I saw the ads for Deck Over and bought into it. One coat, dancing in your bare feet. Easy, Right? Not so much. The advertisement claims it eliminates the danger form splinters. The instructions on the can say to carefully remove all the splinters first. And to remove all the loose paint. So I ended up spending two days cleaning, sanding, replacing nails, sweeping, vacuuming, After having it power washed about a month ago. Then rolling. The TV implies you just roll it on and you are golden. They don't mention all the brushing.
Its like trying to paint with caulking. Enormous amount of work. I did the rails with it also. The can says it will fill and cover gaps up to an eighth inch, and it will, on horizontal surfaces. If you fill a vertical gap and come back in a few minutes it has drooled out. If you drip it on the floor (hard not to do) and leave it for a minute of two, the roller won't flatten it out. I was amazed at that. Tried really scrubbing them with the roller. Ended up using my shoe to flatten them and then re-rolling the area.
In hindsight, I don't think I would do it again. The five gallons of material cost $165. I could have bought new decking for about twice that. It would have been about the same time and amount of work to replace the floor. And, I don't like painting to start with, carpentry is much more satisfying. Now I have an old floor with glop on it and I thing a new one might sell better. Live and learn.
Re: So I used the Deck Over stuff.....
Hum different experiance
Dustmaker Mike
I used the Olympic branded stuff and it rolled on easy with a 3/4 nap roller. I used a brush to cut the edges and rolled it out twice on two different days. The first coat covered the wood alright but the second coat filled the checks and cracks pretty easy. The other stuff I looked at I needed to buy their roller heads and it cost more. I guess I will know in a few years if it was worth the money but for now it looks great.
